Mold Smell In AC - HVAC - DIY Chatroom Home Improvement Forum
Old 06-03-2010, 01:19 PM   #1
Mold smell in AC
Hello All,
Our problem [ hopefully someone can help] involves a smell coming from our heat pump/air conditioner. First we thought it was a mold smell...we installed UV lights, had ducts fogged..and finally put in a whole house dehumidifier.[sized for the house sq ft]
Smell is very caustic...not all people smell it...gets to my throat and eyes tear.
The dehumidifier seems to help until it gets very humid outside. Humidify gauge shows 55% of air coming out of vents and the gauge set in individual rooms can show 60%, even though the humidifier is set to full. When rooms % shows 57% I start to get the smell.
There is no visible mold in the ducts. I have heard of dirty sock syndrome. Could this smell be dirty sock syndrome? I've read that this smell is not irritating.
Is the smell from dirty sock influenced by the humidity? We did not have ducts fogged for this.
Does anyone have any idea what is going on here ...AND what can be done to get rid of the smell?
houndog is offline   Reply With Quote
Old 06-03-2010, 03:07 PM   #2
An old Tradesmen
Rewards Points: 6,904
If the RH coming out of the A/C vents is only 57%. Your A/C isn't working or set up right.
Might want to see if you can seal your house better, to keep the humidity out. Along with fixing the A/C.
The odor could be DSS. In which case. A new indoor coil may be needed.
Old 06-03-2010, 04:04 PM   #3
Rewards Points: 85
Make sure you have a trap on your drain if its a pull through coil.
Was just on a package unit that went to a house, there was no trap so the unit would not drain, the fan housing and supply trunk line was soaked.
Also if the ducts are in a crawl space a return air duct might be sucking in some humid crawl space air.
mikethe ductman is offline   Reply With Quote
Old 06-03-2010, 05:22 PM   #4
What's DSS beenthere?
Old 06-03-2010, 06:27 PM   #5
An old Tradesmen
Dirty Sock Syndrome.
Just gives off an odor like a dirty sock. Its a bacteria growth on the indoor coil.
Musty crawlspace smell coming into house tmpyankee HVAC 6 08-20-2015 09:46 PM
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 08:08 AM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 08:37 PM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 06:56 AM
