Mold Inside Older Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-09-2010, 01:24 PM   #1
I recently attempted to get my furnace serviced and the tech indicated that there was mold inside the furnace on the insulation. Under normal circumstances I would replace the unit. Unfortunately the furnace is in an older condominium where the furnace/heating system cannot be shut down without shutting down the entire community. So, replacing the unit won't be an option until Spring. Until then I need to insure that mold spores are not being filtered through the system and condo.
Is it possible to safely remove and replace the affected insulation? If so,
1. Is this something that a homeowner could do wearing the right protective gear?
2. Is there a certain type of insulation, specific to furnaces, that should be used?
The furnace is probably original to the condo and 30+ years old. I don't know the manufacturer or model number. Unfortunately the tech had no interest in addressing the mold and I'm not even sure if it's something I should expect him to do.
Thanks for any advice and suggestions.
DIYerIT is offline   Reply With Quote
Old 12-09-2010, 01:51 PM   #2
Chicago, IL
Michael Thomas's Avatar
Before doing anything else, take a look here:
http://www.forensic-applications.com/moulds/sok.html
http://forensic-applications.com/moulds/habits.html
http://www.forensic-applications.com/moulds/mvue.html
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
The Following User Says Thank You to Michael Thomas For This Useful Post:
DIYerIT (12-09-2010)
Tags
furnace , insulation , mold
Mold problem after unfinished house was closed in for the winter... lemonbltz Building & Construction 28 12-30-2011 07:52 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
older furnace trouble dags6555 HVAC 1 12-10-2009 06:19 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
