Mold Found On Registers - HVAC - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 08:38 PM   #1
mold found on registers
I'm in the process of caulking all the vent entrances. At two of the registers, I found dots of mold. These two are among the only four that's directly under living space up stairs. They are in a bedroom. The other two are in a bath room and laundry room respectively. and there's no sign of mold on them.
I also noticed that for these four vent entrances, the HVAC company seemed don't care about air leak, because there are big holds on the corners of the tin boxes. I can actually see some wood member through the holes, presumably ceiling joist. Is it because there is living space right above and the air leak doesn't matter? I have the felling that it should still matter. If not why add insulation at all (I see insulation through the holes)?
The tin box above the mold infected registers seems to be clean. I think to thorougly inspect the spot, the flooring of the up stair room has too be removed. Is it that big a concern to justify all that trouble? Or are there easier ways to look into the problem?
deerhunter is offline   Reply With Quote
Smell coming from all floor registers. John_W HVAC 10 08-07-2015 07:42 PM
White dusty spots on dark blue wall!!!!!!!!! Patsfan34 Painting 41 05-26-2015 06:41 PM
Mold growth in basement under shower. Need suggestions to fix leak and clean up mold vseven Plumbing 6 12-10-2009 03:33 PM
mold problem, illegal? elementx440 Remodeling 6 04-09-2007 07:41 PM
