Old 02-01-2013, 11:34 PM   #1
moisture on windows inside
single story 1000 sq ft aprox where should the return be if in wrong place could this stop my problem
screamineagle66 is offline   Reply With Quote
Old 02-01-2013, 11:37 PM   #2
What your location is?
cleveman is offline   Reply With Quote
Old 02-02-2013, 07:16 AM   #3
much more info needed. is this a new problem? all windows? thermopane or single glass? lots of boiling, cooking location? any changes to heating system or inside reconstruction?
condensation is a dew point problem. warm moist air in contact with a cooler surface (below the dew point temperature ) will cause condensation on the cooler surface. If this is a new situation, either there is to much moisture in the air or there has been a breakdown in the insulation value of the effected surface. for example if a thermopane window seal fails, the insulation value of the glass is reduced and the inside temp on the glass in now lower (below the dew point ) and you have condensation.
bernie
bernie963 is offline   Reply With Quote
Old 02-02-2013, 07:16 AM   #4
Moisture on the windows comes from the glass and/or the frame getting cold enough to be below the dew point of the homes humidity. The location of a return will not matter for this problem. Supply air having enough throw to "wash" the windows with warm air will help. The other fixes would be get better windows or add fresh air to lower the RH of the home.
Old 02-02-2013, 07:19 AM   #5
Far more likly causes would be air leaks around the windows, humidity to high in the home.
Which could be from new constrution, using a non vented gas fireplace, no exhost fan in the bathroom or it's not being run long enough, range hood not venting outside, ECT.
Old 02-02-2013, 07:21 AM   #6
Sounds like a high humidity problem at first glance.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 02-02-2013, 07:53 AM   #7
An old Tradesmen
Yep. Return location won't really effect windows condensating.
OP, what is your in RH, and what is you outdoor temp when you see the condensation.
Caulking inside of double pane windows. Shanti Windows and Doors 9 06-23-2012 11:03 PM
Measuring for retrofit windows mday83 Windows and Doors 5 08-14-2011 08:49 PM
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 10:10 PM
Basement moisture - why not seal inside wall? BRO931 Building & Construction 10 08-30-2010 02:47 PM
Moisture on Inside of Sheathing elburritoloco Building & Construction 18 01-19-2009 09:16 PM
