-   -   moisture on windows inside (http://www.diychatroom.com/f17/moisture-windows-inside-170791/)
screamineagle66 02-01-2013 10:34 PM
single story 1000 sq ft aprox where should the return be if in wrong place could this stop my problem
cleveman 02-01-2013 10:37 PM
What your location is?
bernie963 02-02-2013 06:16 AM
much more info needed. is this a new problem? all windows? thermopane or single glass? lots of boiling, cooking location? any changes to heating system or inside reconstruction?
condensation is a dew point problem. warm moist air in contact with a cooler surface (below the dew point temperature ) will cause condensation on the cooler surface. If this is a new situation, either there is to much moisture in the air or there has been a breakdown in the insulation value of the effected surface. for example if a thermopane window seal fails, the insulation value of the glass is reduced and the inside temp on the glass in now lower (below the dew point ) and you have condensation.
bernie
Marty S. 02-02-2013 06:16 AM
Moisture on the windows comes from the glass and/or the frame getting cold enough to be below the dew point of the homes humidity. The location of a return will not matter for this problem. Supply air having enough throw to "wash" the windows with warm air will help. The other fixes would be get better windows or add fresh air to lower the RH of the home.
joecaption 02-02-2013 06:19 AM
Far more likly causes would be air leaks around the windows, humidity to high in the home.
Which could be from new constrution, using a non vented gas fireplace, no exhost fan in the bathroom or it's not being run long enough, range hood not venting outside, ECT.
COLDIRON 02-02-2013 06:21 AM
Sounds like a high humidity problem at first glance.
beenthere 02-02-2013 06:53 AM
Yep. Return location won't really effect windows condensating.
OP, what is your in RH, and what is you outdoor temp when you see the condensation.
