Old 11-06-2005, 10:54 AM   #1
Question
Moisture in Furnace
Without getting into the details too much.....
I replaced a blower motor assembly on my forced air furnace (motor/impeller...whole assembly... even though I only had a broken impeller blade)
now I am noticing moisture collecting in the furnace under the blower assemly..... not much to the replacement, but wonder if I am missing a gasket or something between the housing and the blower .... although none came in the kit.
Any thoughts.
cronkd is offline   Reply With Quote
Old 10-23-2006, 09:57 PM   #2
Thoroughbred Mopar Man
Moisture in Furnace
Hi cronkd
What blower assy did you replace. If it was the inducer assy on a 90 plus you may need to use some silicone. But if it is the main blower assembly you have low air volume, probably due to some kind of restriction in air stream. You could also have a leaking condensate pan on your evaporator coil, or a plugged condensate drain. If you could let me know a little more I can pinpoint it for you.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Furnace not firing jax HVAC 5 02-22-2009 01:41 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 07:10 AM
