Moisture In Air Supply - HVAC - DIY Chatroom Home Improvement Forum
Old 04-04-2006, 01:59 AM   #1
amatchin's Avatar
moisture in air supply
We have a new HVAC system and ductwork. The air blowing out feels damp. What would/could be the cause?:confused:
amatchin is offline   Reply With Quote
Old 04-04-2006, 02:52 PM   #2
Cool
It,s probably just cold. You can not tell by feel you need to check the humidity.
didn'tdoit is offline   Reply With Quote
Old 04-05-2006, 02:28 PM   #3
747
registered
747's Avatar
Rewards Points: 534
some forced air heating system have humdifiers built in them. If your does check the settings on it. In the winter months it will add moisture into the system. So the air won't be dry.
747 is offline   Reply With Quote
Old 04-05-2006, 08:53 PM   #4
amatchin's Avatar
Thumbs up
Thank you. I don't know if my unit has a humidifier built-in. It is an electric heat pump and air handler. The idea of having moisture in the air in the winter time is a great idea, just not in the summer time. This past winter, what little time that we needed to run the heat, there was too much moisture blowing out of the register vents. That was one of my complaints to the contractor. He didn't mention the unit having a humidifier though. I will see if I can find out about my system and give it a check.
didn'tdoit, The moisture is not from the humidity of the day but rather from the air that is blowing out of the registers. I.. feel.. the moisture in the air. Cold air filled with moisture is a lot colder than dry cold air. The HVAC is drawing moisture out of the room but at the same time blowing it back with the cold air through the vents. 75 degrees with 68% humidity, not good.
Old 04-05-2006, 09:29 PM   #5
747
registered
747's Avatar
Rewards Points: 534
I didn't realize you have a electric heat pump. I don't know anything about those because they are popular in hot weather climates. You don't see them up here in the north do to the frigid winters we have.
Old 04-07-2006, 04:53 PM   #6
amatchin's Avatar
747..come to think of it, we never had a heat pump in Illinois either. We lived around the Galesburg area for 15 years...Yes the weather
is frigid indeed. I remember one year we had a -62 degree wind chill.....and alot of snow..the weather is why I left town:D I will take the heat anyday over the cold. Thanks for responding to my problem.
Old 04-07-2006, 09:42 PM   #7
747
registered
747's Avatar
Rewards Points: 534
Galesburg if i'm not mistaken that is about 30 minutes from Peoria. Meaning if your in peoria get on the interstate you will be getting close to galesburg in around 30 minutes...I think 74. isn't it. I could be wrong don't really know that area very well.
To Moisture Barrier or Not to Moisture Barrier? cordon Flooring 7 05-22-2007 10:48 PM
moisture in fridge/freezer diggitydog Appliances 11 10-24-2006 06:21 PM
moisture barrier - help! jediracer Carpentry 12 10-03-2006 07:32 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
