Modulating Furnaces - HVAC - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 03:15 AM   #1
Modulating Furnaces
As I understand there are different versions of modulation ie flame valve burners vs just variable blower speeds. Given the complexities of these, I would expect the repair and maintenance costs would be quite high when they fail, what would be the most proven design today?
Somebody here posted that Ruud has had their modulating unit out longer 12+ years than the others ie lennox, trane Bryant etc for 3-5 yrs. If I go modulating, I may go with Ruud for this reason
Any advice pls?
Liberator is offline   Reply With Quote
Old 01-25-2012, 05:37 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,770
it is wickedly complicated and uses a very expensive tstat. one of the very few furnaces I won't work on. needs a specially trained Rheem tech.
Old 01-25-2012, 07:47 AM   #3
And that tech brings a two hundred and fifty page factory reference manual...
i went to a RSES seminar on the Rheem mod. By the time the Speaker was done talking I had a head ache.
hvac5646 is offline   Reply With Quote
Old 01-25-2012, 08:14 AM   #4
MarginallyQualified
Rewards Points: 2,464
I'm in the market right now for a new system.
After a lot of back and forth with the latest in whiz bang furnace options...
I'm leaning toward a simple controls 80% gas furnace to back up a heat pump.
That it is an inexpensive alternative suits me right down to the ground.
Old 01-25-2012, 10:01 AM   #5
Hvac Pro
yuri's Avatar
buy one with a constant torque ecm motor. they save a lot of electricity $$ and maintain a constant torque and airflow as the filter plugs and have ball bearings instead of cheap sleeve bearings.
http://www.lennox.com/products/furnaces/ML180E/
other brands may have them too. not the same as a variable speed ecm motor but cost 50% less and do almost the same job.
The Following User Says Thank You to yuri For This Useful Post:
TarheelTerp (01-25-2012)
Old 01-25-2012, 12:08 PM   #6
What are the hi end mod furnace brand features should look for please and how would I compare them?
The info on the ball bearing is very helpful
Thank you
Modulating or staged? BlueBSH HVAC 6 12-29-2011 05:00 PM
how does a modulating furnace modulate? raylo32 HVAC 17 08-06-2011 12:14 PM
Twinned Furnaces Questions MrControls HVAC 12 12-13-2008 10:09 AM
2 furnaces 1 thermostat clarnp49 HVAC 3 12-05-2007 08:12 PM
Payne Furnaces mick6311 HVAC 1 06-26-2007 09:10 PM
