Modern Hotwater Radiator In Old System - HVAC - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 09:30 PM   #1
Question
Modern hotwater radiator in old system
I would like to replace an old radiator in my remodeled kitchen with a modern Veha brand radiator. Can you use these in an old (forced) hot water system? What connections need to be made? Can you go from cast iron piping to pex? Not really sure what I'm doing. Looking for insight.
Evan1 is offline   Reply With Quote
Old 09-20-2009, 05:54 AM   #2
An old Tradesmen
Rewards Points: 6,112
If its a stell rad. It will give off heat quicker then the old cast iron rads in the rest of the home. ut won't give it off for as long. And can result in some uneven heat.
Its possible to go from steel pipe to pex. But, the pex has to be sized to flow the proper amount of water.
Old 09-20-2009, 07:03 AM   #3
if you are going from steel pipe to Pex. Make sure you use the right Pex tubing. Must be manufactured for the heat use and not domestic water. Heat Pex has an oxygen barrier. Also keep in mind that most, if not all Pex has a maximum oporating temperature of 180 degrees, so make sure your boiler water temp does not exceed 180. Also when you use Pex tubing make sure you use a fastener or hanger every 4 feet or so because the Pex will expand and sag when heated.
sdsheatcool is offline   Reply With Quote
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 06:24 AM
Installing a New Central Air System vdu HVAC 7 09-01-2009 04:45 PM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 05:50 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
