Model Request - Goodman Attic Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 07:58 PM   #1
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 95
Model Request - Goodman attic unit
Hi, folks.
I'm getting a new heat pump system to replace the late-80's 1.5t Frigidaire split a/c system that is in my attic. It serves the upstairs (4 bedrooms, 1 bath, ~500 sq ft).
I'll be getting a heat pump so I can reduce my oil consumption. My installer wants to put a 4 ton variable unit in.. the 1.5t works very hard and doesn't do well. The insulation is insufficient.. that will also be upgraded. I do want additional capacity to service a 300 sq ft planned addition a few years down the road.
Installer recommends Goodman for quality and value in a higher end unit. I did some reading on here.. seems like most people thing the newer units are pretty good stuff.
What models should I be looking at? I can't seem to find a Goodman attic unit at all.
Thanks!
inK
Hammer in Hand, Dad on Speed Dial
http://www.mydadsshoes.com
ink is offline   Reply With Quote
Old 10-29-2012, 08:34 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Just remember that the higher the seer rating the lower the elecrtical bill. And Amana is Goodman's higher end sister company.
This is an Amana 16 seer data comminucating 3 ton R410-A system, non heat pump. that I installed a few days ago. Heat pump works with this 80% variable speed furnace though. It's an upflow in an attic.
The furnace is multi position. If for a horizontal application the coil would be different.
A/c.
This is the new data communicating stat, $350.00.
I'll find the model numbers for this system in heat pump form for you tomorrow if interested. I live in Houston, where Goodman is made.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
ink (10-29-2012)
Old 10-29-2012, 08:36 PM   #3
ink
DIY Enthusiast
ink's Avatar
Rewards Points: 95
Thanks. I'm assuming you'll fix it and this post won't make sense to everyone later... but you must really love goo gone?
edit: ha! that was quick.
inK
Old 10-29-2012, 08:38 PM   #4
Ha ha!! I forgot to copy the links when I posted them earlier. The goo gone is from an auto truck forum from earlier. ha!
Thanks.
Old 10-29-2012, 09:15 PM   #5
An old Tradesmen
Rewards Points: 6,464
Doubt your house even with a 300 sq ft addition will need a 4 ton. plus, you would need all new duct work, cause the duct work for your 1.5 ton is never gonna handle the air flow a 4 ton would need.
I'd look for other contractors.
The Following User Says Thank You to beenthere For This Useful Post:
carmon (10-29-2012)
Attic a/c unit water in insulation foyjohn59 HVAC 15 03-06-2016 11:57 AM
60 ton Trane rooftop unit Model SAHA 600... RTG Service HVAC 4 08-07-2012 07:31 AM
Goodman Furnace Model Number GMNT080-4 msgbob79 HVAC 15 12-28-2011 12:07 AM
Insulation under attic AC unit nickelshine General DIY Discussions 0 12-13-2010 03:30 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 08:30 PM
