Model No. 24ABR330A310 Series No. 0306E15544 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-25-2012, 07:16 PM   #1
Model no. 24ABR330A310 Series No. 0306E15544
What is the warranty status on compressor?
Lmunozro is offline   Reply With Quote
Old 11-25-2012, 07:41 PM   #2
Rewards Points: 616
could be zero or years left....need to find who installed it and where it was bought from...... whats the application the compressor is in
carmon is offline   Reply With Quote
Old 11-25-2012, 07:43 PM   #3
Items wanted: Time
Rewards Points: 150
http://www.carriergreatlakes.com/
NiNe O is offline   Reply With Quote
Old 11-25-2012, 08:10 PM   #4
Well, the house is located in So. Florida.
The builder is Standard Pacific, and I bought the house from the builder in May 2006 (original owner).
Old 11-25-2012, 08:16 PM   #5
Items wanted: Time
Rewards Points: 150
if that is a "builders model" the compressor is more than likely out of warranty. Call the number in the link I posted and they should be able to tell you the deal. Have the model and serial of the condensing unit handy.
Old 11-25-2012, 08:17 PM   #6
Rewards Points: 616
i would suspect the warranty is over.....
Old 11-26-2012, 12:07 PM   #7
You're right, it is expired. The unit is only 6 1/2 years old and they will not "help" me a little bit.. I will send a letter to the builder (Standard Pacific) and other builders around here letting them know about Carriers customer service.
Old 11-26-2012, 12:11 PM   #8
Items wanted: Time
Rewards Points: 150
That compressor failed due to improper installation, more than likely. If you have it replaced, be sure your contractor tells you why it failed and that they take steps to insure it won't happen again.
Old 11-26-2012, 03:06 PM   #9
HVAC Tech/Owner
Rewards Points: 604
Why are you blaming carrier's customer service? If the warranty is expired, then its expired!
Like others have said...who installed it?
Did you have annual maintenance on it?
Technow is offline   Reply With Quote
Old 11-26-2012, 04:11 PM   #10
An old Tradesmen
Rewards Points: 7,274
All brands have the same 5 year compressor warranty on their builder grade units.
Builder grade is basically bottom of the barrel. Perhaps your letter to builders should be thanking them for requiring the cheapest model line be installed.
Next, you need a company that will find out why it died so soon.
Lennox Elite Series Heat Pump Model Number 10hpb24-9p Fan Not Turning On gecollins HVAC 0 04-05-2012 10:44 AM
Need Manual for Burnham Holiday Model 6-61 Series 2 Andrea Culo HVAC 3 01-24-2012 09:21 AM
Weil McLain Model E-6 Series 2 dkubiak HVAC 1 08-14-2011 11:21 AM
Weathermaker SX Model 58SX080-BC-1 Series 150 leaking hose vel1975 HVAC 1 01-12-2011 08:24 PM
Weathermaker SX Model 58SX080-BC-1 Series 150 DONJ HVAC 2 12-06-2010 03:55 PM
