Mobile Home Furnace Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 03:24 PM   #16
Ok. I'll try to get them up as soon as I can.
colu41 is offline   Reply With Quote
Old 10-14-2011, 03:38 PM   #17
I'm pointing at the switch. The 2 wires that go into it when hardwire, the fan works but blows cold air. When the switch is hooked up, fan does not turn on.
Sorry about pic size. Didn't think my phone cam would leave it that big
Old 10-14-2011, 05:07 PM   #18
An old Tradesmen
Rewards Points: 7,344
In the small box on the left, is there a relay?
The fan switch is a temp activated switch, it has to sense 110 degree temp before it will bring on the fan.
The Following User Says Thank You to beenthere For This Useful Post:
Doc Holliday (10-14-2011)
Old 10-14-2011, 05:56 PM   #19
Not sure. Want me to take a pic of everything?
The pilot doesn't seem like its hot enough to heat up the blower switch.
Old 10-14-2011, 06:38 PM   #20
An old Tradesmen
The pilot shouldn't generate enough heat to start the blower. Your furnace may have a sequencer/timer in that left side, also.
Old 10-14-2011, 08:39 PM   #21
I dont have a volt meter. BUT. I found this (similar looking to this), and tried arcing it to see if it had power, and got nothing. What is it?
Old 10-14-2011, 09:42 PM   #22
An old Tradesmen
Its a relay, often used to control a fan. Attempting to arc it can cause more damage to your transformer, so don't attempt it again.
Old 10-14-2011, 09:51 PM   #23
REP
I hate to say this but you have gone beyond your ability to correct your problem.
I believe that you have a problem that would be easy and cheap to fix but at this point you can only make the problem worse.Please call you HVAC repair guy,it shouldn't be an expensivwe fix.
REP is offline   Reply With Quote
mobile home furnace wires keep burning off p5200 HVAC 5 03-04-2011 03:42 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Mobile Home Furnace problem jbenn003 HVAC 1 12-01-2008 05:08 PM
Mobile home furnace problem graphic master HVAC 2 11-19-2008 12:12 PM
