#1 |
Mobile Home Furnace Problem
I have a mobile home with an electric furnace. Now I have a fan switch that is bad. BUT, when I hardwire the wires together, the fan obviously turns on, but blows cold air. Is there another problem? Or will the fan switch fix this also?
The fan switch when bad last year also. Had a tech come in to diagnos but, found nothing but the fan switch. Any help would be greatly appreciated. |
#2 |
An old Tradesmen
Could be a heat sequencer is bad.
#3 |
Where would that be located?
#4 |
What is this fan switch that is bad?
Is it the fan relay, or the thermostat? |
#5 |
There has to be a relay,contactor,sequencer ,something that puts line voltage to the heating elements and or fan.
This usually has a low voltage coil that the stat energizes on a call for heat. |
#6 |
HVAC Tech/ Browns Fan
sequencer sound to be that problem or limit. also need to find what took it them out. I can be dirty filter or even plugged coil if has a/c.
#7 |
It does have AC.
and this is the part thats bad well, thats what I noticed first. Didn't check the switch next to it
#8 |
That's a thermal fuse.
#9 |
Mobile Home Furnace Problem |
#10 |
That is not a fuse,its a switch.It is normally open,when it senses 110 degrees it makes the circut,when it then senses 90 degrees it opens again.
There very well could be a fuse in line with the heating elements that would have opened if the fan didn't come on to cool the plenum. You really need a meter to check electrical systems out. |
#11 |
Can you take a picture of the actual switch, and the wiring in the unit..something here is not right.
#12 |
Finally got time to pick up a new switch. Plugged it in and the fan doesn't even turn on now.
Do I need to wait for it to heat up or something before it turns on? |
#13 |
#14 |
| Display Modes | |
| mobile home furnace wires keep burning off | p5200 | HVAC | 5 | 03-04-2011 04:42 PM |
| Furnace Model # Feh-015-04 clicking but not turning on? | haimei | HVAC | 1 | 12-14-2010 06:01 PM |
| Problem with Lennox Pulse Furnace Wiring to Thermostat | scalvin | Electrical | 4 | 12-30-2009 08:48 PM |
| Mobile Home Furnace problem | jbenn003 | HVAC | 1 | 12-01-2008 06:08 PM |
| Mobile home furnace problem | graphic master | HVAC | 2 | 11-19-2008 01:12 PM |
