Mobile Home Furnace Keeps Shutting Down - HVAC - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 12:33 PM   #1
mobile home furnace keeps shutting down
i have a thermo pride mobile home burner that i use to burn kerosene. the oil company switch hands and supplied me home heating oil#2 the burner keeps shutting down after a week or so due to carbon on electrodes. oil repai man keeps cleaning it instead of replacing it. should i go back to kerosene. also nozzle and screen has been changed.
wfitzp1015 is offline   Reply With Quote
Old 02-21-2013, 04:55 PM   #2
An old Tradesmen
Rewards Points: 7,814
Regular heating oil won't harm it. The new nozzle may not be the right spray angle. Or may be a bad one out of the box.
Old 02-21-2013, 10:04 PM   #3
mobile home furnace keeps failing
the service man change the nozzle 2 or 3 times in the past 6 weeks. clean the electrodes a times. the mobile home burner thermo pride is ten years old the first five years no problem been burning kerosene. the last five home heating oil#2 . might had problem once each year in the last five years, except this year since october the serviceman must of came by 6 times. is it time for a new one. 2 of the servicemen told me to go back to kerosene which there company dont carry anymore. dont know what to do.
Old 02-22-2013, 04:12 AM   #4
An old Tradesmen
Is your burner on a single or 2 pip oil line. If 2 pipe, there may be a slight air leak in the supply line and that can cause what your having.
The Following User Says Thank You to beenthere For This Useful Post:
wfitzp1015 (02-24-2013)
Old 02-23-2013, 01:02 PM   #5
The oil tank is on a two line pipe system. Im thinking of getting another oil tank with a one pipe system. The tank is kind of old and also putting new tank in diffrent location.
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 08:53 AM
Coleman DGAA mobile home furnace issue baluna HVAC 9 04-07-2012 08:55 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Leveling Mobile Home Ceiling myowneq Building & Construction 4 01-16-2012 06:06 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
