Old 10-02-2011, 01:26 PM   #1
Unhappy
mitsubishi split system
we installed a mitsubishi split system mxz-4b36na. the a/c worked great in the summer but now we turned on the heater and it is blowing cold air instead of warm. we turned on the 4 inside units and it is the same problem. it is not blowing warm air. what could be the problem?
gherlain is offline   Reply With Quote
Old 10-02-2011, 02:00 PM   #2
Professional
call mitsubishi. They do not operate as normal hvac equipment. Also download your manual from mehvac.com it will give some troubleshooting help.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-02-2011, 09:00 PM   #3
HVAC Tech/ Browns Fan
Need make sure its hook up right and the reversing valve is shifting. I work on that kind unit all the time and did find reversing valves are bad. Matter fact the supply house were we get parts from say that recall had been sent out for those units.
Tator1076 is offline   Reply With Quote
Whats a good 3ton Heat-Pump split system to buy? ehoez HVAC 6 07-14-2011 10:11 AM
Split System Line Set Sizing yogi_bear_79 HVAC 5 04-18-2011 09:18 AM
Installing a New Central Air System vdu HVAC 7 09-01-2009 04:45 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
