Mitsubishi Mr Slim - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 06:51 AM   #1
Mitsubishi Mr Slim
What's needed in the wall before installation? I see in manual ref lines, 220 power, drain line... Is there control/thermostat wire needed also? I can't find specific requirement...
Thanks!
bubpeter is offline   Reply With Quote
Old 12-15-2011, 08:12 AM   #2
HVAC Tech/Owner
Rewards Points: 604
A "hole" to get all those lines thru.
Technow is offline   Reply With Quote
Old 12-15-2011, 10:14 AM   #3
All the lines, drain, power are buried in the new wall, set to go. Blocking in place to hold evap. Is there low voltage communication wire involved here? What controls cond unit outside? Pressure?
Old 12-15-2011, 02:19 PM   #4
biggles's Avatar
if the transformer is in the evaporator section you need stat wire pull to the condenser and the thermostat so the stat can control the evap and condenser heat or cooling
Old 12-15-2011, 07:09 PM   #5
I guess I need to get deeper in to these instructions, thanks!
Old 12-16-2011, 07:28 AM   #6
Rewards Points: 1,214
What controls the outside unit? Pressure? No.
Most of those units are wireless remote thermostat operated which controls everything from the inside.
COLDIRON is offline   Reply With Quote
Old 12-16-2011, 10:43 AM   #7
I still see nothing about running tstat cable. I think I'm all set...
Thanks... not moving the cond unit outside until Spring now...
mitsubishi 1 ton mini-split ag1380 HVAC 2 10-14-2011 06:50 PM
Flared connections inside wall in Massachusetts (Mitsubish Mr. Slim) ChootarLaal HVAC 5 07-21-2011 09:27 PM
Anyone know about ductless AC systems like the Mitsubishi Mr Slim? jayp HVAC 3 06-19-2009 10:50 AM
Mitsu Mr. Slim opinions? poger67 HVAC 1 05-31-2009 08:31 PM
Mr. Slim ductless air cooling systems robertmazzo HVAC 3 10-20-2006 10:02 PM
