"The Mister" - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2013, 01:07 PM   #1
Rewards Points: 640
"The Mister"
Anyone else see these things that they are trying to pawn off to home owners? Claiming to make your AC unit work 30% more efficient by spraying a mist of water "around" the AC unit outside while it runs.... I duno when I saw the commercial I just had to laugh
House Information: Build 1996, 1500 sq ft basement, 1500 sq ft 1st floor, 800 sq ft 2nd floor, 560 sq ft unfinished attic space on 2nd floor. Insulation: Attic blown fiberglass, walls R-19, Basement R-19. HVAC: Trane xc95m fully modulating furnace, single zone, Trane XL20i commiunicating AC unit, TCONT900 Communicating thermostat.
BlueBSH is offline   Reply With Quote
Old 07-01-2013, 05:35 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 134
Snake oil. I can just imagine when the water mineral coats the fins and when the water turns the dirt and dust on the coil into C Ment what that will do for the E fishncee.
Old 07-01-2013, 09:51 PM   #3
as seen on tv
Rewards Points: 150
Its not correct but it does increase capacity on hot days
qbert is offline   Reply With Quote
The repair is "The Bomb" tenzo HVAC 3 06-27-2013 10:04 AM
"The Pit" or future wine/storm cellar or mechanical room scootermcrad Building & Construction 6 12-05-2012 09:33 PM
Anyone used "The End Rot" wood restoration kit to repair rot woods Andee77 Painting 2 07-31-2012 02:35 PM
Front porch - "The Leader of the Pack" rossfingal Off Topic 13 12-29-2011 08:14 PM
Delta-FL "The Warm & Dry Floor Systm joedadog Flooring 4 04-11-2009 05:40 PM
