Missing Vent Pipe In Recessed Dryer Box...solutions?? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 09:47 PM   #1
missing vent pipe in recessed dryer box...solutions??
i have an issue...
just bought a house with the recessed dryer vent box...the pipe that is suppose to go through the "oval" hole appears as if it was either cut off or wasn't installed the 2 inches or so through, into the box portion. It appears the recessed box was actually cut to the round shape, instead of forming to the oval...the pipe is pretty much flush with the recessed box
so, i'm curious what the best countermeasure is to hook up my dryer?
is it simply to add a say...5" piece that inserts inside the existing pipe, then use that to tie the foil/aluminum hose into? seems easy enough, but i worry about the heat/lint getting past the metal on metal "joint" and into the framework since i can't tape off the joint..
suggestions??? thanks in advance!!!
tsteffel is offline   Reply With Quote
Old 12-05-2012, 12:04 AM   #2
Rewards Points: 13,296
Got a picture?
Should not be using that type hose, it's a fire hazard.
Since it's behind a wall it should be soild pipe.
And it's 4" not 5".
Old 12-05-2012, 11:35 AM   #3
from your post, it sounds like the contractor did not allow the rigid pipe to penetrate into the Dryerbox the recommened 2", or that he did, but when he was done running the pipe, it actually disengaged or came out of where it rested.
In any case, the oval hole will accomodate the 4" rigid pipe, and you may be able to find it, steer it, and get it back through the opening or port.
if not, we have this 4" long crimpedon one end collar that would snug or friction fit into the pipe, and give you back the 2 inches of rigid to connect the flex to.
See this video:
Collar link:
http://store.dryerbox.com/Crimped-Co...ong_p_106.html
Really niffty alternative to the two flex options:
Hope this helps. feel free to call me.
contact info at www.dryerbox.com Thanks
Rick
rickharp is offline   Reply With Quote
Frozen Vent Pipe Ratchye Plumbing 55 01-17-2017 06:21 PM
Dryer vent problem carguy4sp General DIY Discussions 7 11-29-2010 09:26 AM
Vent cap size ok for dryer? chazman113 Roofing/Siding 4 07-27-2010 11:39 PM
Dryer Vent type? cbzdel General DIY Discussions 6 06-08-2010 09:17 PM
Vent Pipe Leak romeguy1 Plumbing 9 12-11-2005 01:08 AM
