#1 |
Misc DIY questions
Hello,
Just a few pseudo-random questions: * On the system with the chopped-out condenser: what steps should I take to ensure a clean system? I envision just blowing it out with nitrogen. Will the TXV impede this? Should I shoot some kind of solvent through it ( I know there are kits ) to purge any remaining compressor oil? The new condenser will come with its own oil, right? * Is "Sil-Fos 15" appropriate for all the brazed connections? The big HVAC book suggests that on the suction side, the high temperatures may kill the temper of the tubing. Unless it's already annealed, in which case it doesn't matter.... Or does it? * I see that one can buy mounting pads for the condensers, and also flexible stainless steel hoses to isolate their vibrations. Would such be a good investment in peace and quiet? Or are new condensers with scroll compressors plenty quiet anyway? - JerryK |
#2 |
Misc DIY questions
don't flush it with nothing but nitro...
the oil from the old system is just wet on the inside of the pipes thru out and the TXV has an equalizer to pass the nitro but with the unit in change out mode the valve will probably will be open to pass it...brazing cool just be clean on the connection with a little flux back the torch away to control the heat...and the cork/rubber waffles or mint for a pad and yes the scrolls are supper quiet...
#3 |
Misc DIY questions
Cut the copper back a few feet to eliminate any dirt contamination. Blowing it out with nitrogen is fine. The heat required for silfos does take the temper out of the copper at the joint but it's still able to withstand pressures like 80 times what your AC will ever produce. It's a non-issue. I've never seen flex hoses needed on a residential AC so doubt you need them. Keep the line set from touching wood to control vibration transfer.
#4 |
Hvac Pro
Misc DIY questions
If you want to REALLY protect your new system from any contaminants or who knows what got in there while it sat open for a long time you may want to install a suction line filter drier. NOT cheap. may cost you $100 as a non contractor but I think it is worth it. Depending on which brand and model of condensors you buy they may have a small internal liquid line filter drier but some require you to add one yourself external to the condensor. Need to look inside it for a small copper bulb/drier on the liquid line or they may or may not include it in a loose box with the condensor. You now need to be quite skilled to quickly weld with it wrapped in a wet rag so it does not burn inside. Also need to wrap the service valves with a wet rag and remove the cores with a core remover. You are going to need a set of refrig gauges and a vacuum pump with clean oil and a micron gauge so the project starts to get more complex. Feeling up to it?
![]() http://www.emersonclimate.com/en-US/...er_driers.aspx
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by yuri; 08-13-2011 at 08:50 AM. |
#5 | |||
Misc DIY questionsQuote:
*** So I take it you recommend a suction line filter even if the mfgr included one in the liquid line? This one does, according to the poop sheet. Quote:
*** Already have two charging manifolds. One with dials calibrated for R22, the other one that I use for R134A conversions on old cars. There's a guy on the local craigslist advertising a Mastercool digital manifold, complete with micron gauge. I've been blasting him with emails. He has not answered any of them .*** Just received two brand new quarts of oil for my Robinair 15600. two-stage, 6 CFM. *** See my post from earlier this morning "Test Equipment on a shoestring". Gotta get a micron gauge. Otherwise, I won't know if I successfully evacuated the system. Feeling up to it? ![]() *** Yup. - JerryK http://www.emersonclimate.com/en-US/...er_driers.aspx[/quote] |
#6 | |
Hvac Pro
...... am not sure what the difference between the 8 and regular one is and would have to talk to my wholesaler if I was to use it. maybe the other guys know. whichever is more expensive is the better one and stronger.click on stay brite 8 and go to their resources link and then Guide for some good useful info, http://www.harrisproductsgroup.com/e...tay-Brite.aspx http://www.harrisproductsgroup.com/e...y-Brite-8.aspx http://www.harrisproductsgroup.com/e...Brite-Kit.aspx
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by yuri; 08-13-2011 at 10:50 AM. |
#7 |
An old Tradesmen
Misc DIY questions
am not sure what the difference between the 8 and regular one is and would have to talk to my wholesaler if I was to use it. maybe the other guys know. whichever is more expensive is the better one and stronger.click on stay brite 8 and go to their resources link and then Guide for some good useful info, http://www.harrisproductsgroup.com/e...tay-Brite.aspx http://www.harrisproductsgroup.com/e...y-Brite-8.aspx http://www.harrisproductsgroup.com/e...Brite-Kit.aspx[/quote] The slightly higher amount of silver in stay brite 8 causes it to have a higher melting temp, which allows better bonding. Its just a change in tin and silver make up. |
#8 | |
- JerryK |
#9 |
An old Tradesmen
Misc DIY questions
What you call plastic. Is I believe called fluidous. Not a solid, and not a liquid.
#10 |
Hvac Pro
Misc DIY questions
Thats what I get when I drink TOO much beer and eat chili
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#11 |
Misc DIY questions
Stop using big words..it hurts!
#12 |
Hvac Pro
Misc DIY questions
elasticity, plasticity, fluididity, co-efficient of performance, need a Tylenol now?
#13 |
Misc DIY questions
Your unscroupulous malificient indifference towards my socio-economic predispositional conditioning can no longer be deemed justifiable by any disproportionate standards. I will recommend your dispatching, post haste.
#14 | |
- JerryK |
#15 | |
Hvac Pro
| Display Modes | |
| Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions | Tryvidy | Electrical | 9 | 06-18-2012 03:37 PM |
| Basic (hopefully) electrical questions | k2000lbs | Electrical | 10 | 04-27-2011 01:59 PM |
| Misc. Building Questions | ws450r | Building & Construction | 2 | 02-10-2011 04:35 PM |
| How thick should my thinset be? | yummy mummy | Tiling, ceramics, marble | 20 | 09-28-2009 01:36 PM |
| Laminate wood floor layout questions | nathan.tran | Flooring | 4 | 08-30-2008 11:56 PM |
