-   -   Misc DIY questions (http://www.diychatroom.com/f17/misc-diy-questions-113847/)
jerryk1234 08-12-2011 09:44 PM
Misc DIY questions
Hello,
Just a few pseudo-random questions:
* On the system with the chopped-out condenser: what steps should I take to ensure a clean system? I envision just blowing it out with nitrogen. Will the TXV impede this? Should I shoot some kind of solvent through it ( I know there are kits ) to purge any remaining compressor oil? The new condenser will come with its own oil, right?
* Is "Sil-Fos 15" appropriate for all the brazed connections? The big HVAC book suggests that on the suction side, the high temperatures may kill the temper of the tubing. Unless it's already annealed, in which case it doesn't matter.... Or does it?
* I see that one can buy mounting pads for the condensers, and also flexible stainless steel hoses to isolate their vibrations. Would such be a good investment in peace and quiet? Or are new condensers with scroll compressors plenty quiet anyway?
- JerryK
biggles 08-13-2011 06:39 AM
don't flush it with nothing but nitro...:wink: the oil from the old system is just wet on the inside of the pipes thru out and the TXV has an equalizer to pass the nitro but with the unit in change out mode the valve will probably will be open to pass it...brazing cool just be clean on the connection with a little flux back the torch away to control the heat...and the cork/rubber waffles or mint for a pad and yes the scrolls are supper quiet...
Marty S. 08-13-2011 06:59 AM
Cut the copper back a few feet to eliminate any dirt contamination. Blowing it out with nitrogen is fine. The heat required for silfos does take the temper out of the copper at the joint but it's still able to withstand pressures like 80 times what your AC will ever produce. It's a non-issue. I've never seen flex hoses needed on a residential AC so doubt you need them. Keep the line set from touching wood to control vibration transfer.
yuri 08-13-2011 07:45 AM
If you want to REALLY protect your new system from any contaminants or who knows what got in there while it sat open for a long time you may want to install a suction line filter drier. NOT cheap. may cost you $100 as a non contractor but I think it is worth it. Depending on which brand and model of condensors you buy they may have a small internal liquid line filter drier but some require you to add one yourself external to the condensor. Need to look inside it for a small copper bulb/drier on the liquid line or they may or may not include it in a loose box with the condensor. You now need to be quite skilled to quickly weld with it wrapped in a wet rag so it does not burn inside. Also need to wrap the service valves with a wet rag and remove the cores with a core remover. You are going to need a set of refrig gauges and a vacuum pump with clean oil and a micron gauge so the project starts to get more complex. Feeling up to it?:)
http://www.emersonclimate.com/en-US/...er_driers.aspx
jerryk1234 08-13-2011 09:05 AM
*** $47.99 plus shipping from alpinehomeair. Definitely. Given that this is on the low side, how about soldering it with plumbing solder? That would minimize the heat involved.
*** Goodman GSC130301-DRY for the upstairs system ( that still has a furnace ).
*** So I take it you recommend a suction line filter even if the mfgr included one in the liquid line? This one does, according to the poop sheet.
*** No biggie. I was impressed by how *easy* the brazing process is.
*** Already have two charging manifolds. One with dials calibrated for R22, the other one that I use for R134A conversions on old cars. There's a guy on the local craigslist advertising a Mastercool digital manifold, complete with micron gauge. I've been blasting him with emails. He has not answered any of them :huh:.
*** Just received two brand new quarts of oil for my Robinair 15600.
two-stage, 6 CFM.
*** See my post from earlier this morning "Test Equipment on a shoestring". Gotta get a micron gauge. Otherwise, I won't know if I successfully evacuated the system.
Feeling up to it?:)
*** Yup.
- JerryK
http://www.emersonclimate.com/en-US/...er_driers.aspx[/quote]
yuri 08-13-2011 09:21 AM
I should start charging $$ for my advice. LOL. Actually there is a solder called Stay_Brite which uses a flux and requires considerable skill but it is low temp and can be used where there is minimal vibration and on the low side. I absolutely love it as I don't have to drag a big torch out but it is a one shot deal and if you don't clean the joint 1000% perfectly and flux it and not overheat it it works great. Usually a turbotorch on a Mapp gas hand held cylinder or your little Meco is all that would be needed. Still need to use a wet rag on the driers and service valves. I have used it on all joints high and low pressure EXCEPT the discharge line from the compressor which is VERY hot and vibrates but I am HIGHLY skilled with welding. ONLY works on PERFECTLY clean joints with NO oil residue or freon vapors and that is why we don't use it on repairs as sometimes you get oil burning/vapors and silfoss can tolerate that. If you purge it for a minute or 2/give it a GOOD 150 psi blast B4 welding and purge it while welding you should not get any burning or vapors but you being a newbie to this stuff I don't want to be indirectly responsible for any future problems or angst. LOL.
Yep, you may have several yrs of moisture buildup or corrosion or even acid buildup in those lines from being exposed to the atmosphere for that long
FAMOUS LAST WORDS!!!
two-stage, 6 CFM.
Feeling up to it?:)
*** Yup.
- JerryK
[/quote]
am not sure what the difference between the 8 and regular one is and would have to talk to my wholesaler if I was to use it. maybe the other guys know. whichever is more expensive is the better one and stronger.click on stay brite 8 and go to their resources link and then Guide for some good useful info,
http://www.harrisproductsgroup.com/e...tay-Brite.aspx
http://www.harrisproductsgroup.com/e...y-Brite-8.aspx
http://www.harrisproductsgroup.com/e...Brite-Kit.aspx
beenthere 08-13-2011 10:55 AM
http://www.harrisproductsgroup.com/e...Brite-Kit.aspx[/quote]
The slightly higher amount of silver in stay brite 8 causes it to have a higher melting temp, which allows better bonding. Its just a change in tin and silver make up.
jerryk1234 08-13-2011 11:05 AM
*** 6% versus 4%. But it also makes a difference in the flow. The 4% stuff is eutectic. That is, it is either solid or liquid, with no plastic inbetween. The "8" version has a plastic range from 430F to 535F.
- JerryK
beenthere 08-13-2011 11:16 AM
What you call plastic. Is I believe called fluidous. Not a solid, and not a liquid.
yuri 08-13-2011 11:27 AM
Thats what I get when I drink TOO much beer and eat chili:thumbup:
Master of Cold 08-13-2011 11:54 AM
Stop using big words..it hurts!
yuri 08-13-2011 12:02 PM
elasticity, plasticity, fluididity, co-efficient of performance, need a Tylenol now?:yes:
Master of Cold 08-13-2011 12:16 PM
Your unscroupulous malificient indifference towards my socio-economic predispositional conditioning can no longer be deemed justifiable by any disproportionate standards. I will recommend your dispatching, post haste.
jerryk1234 08-13-2011 12:19 PM
*** And supercalafragilisdeexpialidocious to you too!
- JerryK
yuri 08-13-2011 12:28 PM
3 Attachment(s)
Now are we talkin Cavemen or Bubba?:laughing:
