Mini Splits - How Low Can They Go? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-16-2010, 05:24 PM   #1
DIY Homeowner
Rewards Points: 79
Mini Splits - How low can they go?
Does anyone know of a mini-split heat pump that allows you to set the indoor temperature as low as 45-50 F? I'm talking about winter heating here, not a walk-in cooler. I'd like to get one that will allow a very low setting, just high enough to prevent freezing problems while the dwelling is not occupied. I have a Friedrich that only allows settings down to 60 F.
Also, is there a mini-split system that does better than others in cold weather. Can any of them work below 0 degrees F? Do they automatically shut down when it gets too cold. My Friedrich kept right on running (and heating pretty well) down to 10 F. That's as cold as its gotten since installing it.
BRO931 is offline   Reply With Quote
Old 08-16-2010, 08:22 PM   #2
An old Tradesmen
Rewards Points: 8,236
I believe Mr. Slim works down to -10.
Mini Splits - Always On & Auto vs. Cool function mobiledynamics HVAC 2 08-23-2010 02:39 PM
mini breakers a bad choice? debiasio Electrical 17 08-18-2010 02:27 PM
Honeywell mini zone and generator power daddyrabbit HVAC 2 02-12-2010 10:09 PM
DIY mini splits benjamincall HVAC 1 01-23-2009 08:44 AM
DIY Mini splits - Reality Check - What does it take? Leah Frances HVAC 8 12-17-2008 12:04 PM
