Mini Splits - Always On & Auto vs. Cool function
For ya'll minisplit gurus, couple of questions.
Is a minisplit either *on or off* - meaning it does not cycle whenever it is on. I have a Inverter driven Mitsubishi FE and GZ series. For example, if I set it at 78F on cooling mode and auto fan, the fan is constant and never *stops*.
Not quite sure why the behavior is as such as well, but if I put the minisplit on *AUTO* temp mode and set the temp to 75F for example, it does not RAMP up the fan as high as if I set it to COOL mode with AUTO Fan.
I would assume the *auto* mode just switches between Cooling vs. Heat, but it seems to be less *powerful* on initial operation that if I just switch to Cool with Auto Fan.
Thoughts, advice, suggestions.
