-   -   mini split Wiring question??? (http://www.diychatroom.com/f17/mini-split-wiring-question-50115/)
mjebril 08-02-2009 02:43 PM
Hello,
i bought a mini split system and the wiring between the indoor and the outdoor units confuses me. I was going to have a 30A disconnect between the service panel and the outdoor unit. According to the wiring diagram, i need another 20A disconnect between the Indoor and the Outdoor units along a 5A breaker / or a fuse between leads S1 & S2. can someone explain this to mehttp://hvac-talk.com/vbb/images/smilies/confused.gif. Thanks!!!
Attached Thumbnails http://hvac-talk.com/vbb/attachment....1&d=1249240458
jerryh3 08-02-2009 03:06 PM
I believe some jurisdictions require a disconnect for this line because it feeds line voltage back into the house for the fan motor. Ask your inspector if you need the disconnect. Are you in the UK?
mjebril 08-02-2009 04:28 PM
No! I am in Texas.
jerryh3 08-02-2009 04:54 PM
What is the model number?
mjebril 08-02-2009 06:06 PM
it is a 2.5 ton cooling Fujitsu unit. ASU30/36CLX. i know how to read the diagram, but doesn't know what it translate to hardware wise or is it necessary. i know it is essential for a regular central system. on this, all the literature connects straight from outdoor to indoor with fuse or a disconnect
jerryh3 08-02-2009 06:31 PM
Again, this can only be answered by your inspector. I just had a quad zone Mitsu system installed ,and the company did not use disconnects between the outdoor and indoor units. I just ran a 30A fused disconnect(w/ 20A time delay fuses) for the outdoor unit and that's all.
