Mini Split - Wall Or Ground Mount? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-25-2013, 02:03 AM   #1
Rewards Points: 1,016
Mini Split - wall or ground mount?
Planning stages of a master bedroom addition to my home. Using a mini split unit to provide for heat and a/c. What are the pro & cons of wall vs. ground mounting the outside unit?
I like the idea of wall mounting to keep it higher under the eave, away from lawn mower clippings being blown on it and trimmers doing any damage. But I am concerned of additional noise transmittal into the bedroom.
Thanks in advance!
Vince
____________
Vince
Old 03-25-2013, 08:30 AM   #2
Rewards Points: 13,296
I'd set it on the ground up on a platform out behond the drip line of the roof.
Easyer to service.
0 chance of water damage to the wall.
I build my platform big enough that I could also set my gen set on it.
I dig out all the top soil sprayed with total vegitation killer, installed steel landscape border then back filled the area with stone so I do not have to deal with grass or weeds growing under or near it.
Old 03-25-2013, 09:00 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,426
ground mount because ease of service is a huge issue. on some of them you have to remove the entire top and cowl etc to get in an PROPERLY clean the condensor coil. not something you want to do up in the air and with a hose either.
Old 03-25-2013, 12:30 PM   #4
Just one more thing I'll throw in here. Is the unit a heat pump? If so, if you get much snow in your area I'd recommend setting it above the normal snow line in your area. I know in our area we rarely have more than a foot of snow on the ground, so even a foot or two off the ground will do some good. You just want to make sure it's high enough to keep it out of the snow, but not too high to be able to work on easily.
JScotty is offline   Reply With Quote
Old 03-25-2013, 12:35 PM   #5
Hvac Pro
yuri's Avatar
SoCal I assume that is southern California? Doubt that snow is a problem there but you never know. Unlike the Great White North where I am and we have 150 percent more snow this yr than average. The unit needs to be above ground in cold locales so the water can drain from it and not make a huge iceberg when it defrosts in heat mode and kept away from where snow drifts may bury it.
Old 03-25-2013, 12:49 PM   #6
Didn't think to check his location. Yeah snow in SoCal probably isn't a big concern
Old 03-25-2013, 05:26 PM   #7
An old Tradesmen
Rewards Points: 6,544
A foot or 2 off the ground will give it the protection you want, and still make it easy to service.
Old 03-25-2013, 09:04 PM   #8
No snow here - I don't do snow.
What about my concern of additional noise transmittal with a wall mount?
____________
Vince
Old 03-25-2013, 09:08 PM   #9
An old Tradesmen
Mini splits are very quiet. Shouldn't have any noise problem with it being wall mounted.
Old 04-07-2013, 03:39 AM   #10
Thanks everyone for the great comments! I think wall mounted a couple feet off the ground is best for my scenario.
____________
Vince
Mounting Corner Wall Mount Sink petedickson82 Plumbing 2 02-17-2010 10:28 PM
wall mount toilet jjrbus Plumbing 8 11-12-2009 02:07 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
What's behind the wall? Trying to mount tv... callmedpit Home Theater 4 01-01-2009 10:51 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
