Mini Split System Sizing - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 06:47 AM   #1
Rewards Points: 91
mini split system sizing
i get a wide range of answers on required sizing for a min split system. is there an acurate formula for this? i am planning on using zoned mini splits with heat pump for an addition i am building and cant wrap my head around required size for area.
addition is 20'x40'
1 room (zone) is living room 21' x 20' with cathedral ceiling with peak at 13', with 41' of exterior wall and 2 windows that are 5' x 5' each
2nd room is bedroom 18'x15' with cathedral ceiling with peak at 13' and 33' of exterior wall and 2 windows 2'-6"x 4' each
3rd room is bathroom at 5' x18' with 23' of exterior wall and 2 windows 1'-6"x2'-6"
i figure 1 outdoor unit and 3 zones, 2 12k zones and 1 9k zone. does this sound acurate?
gwilkrrs is offline   Reply With Quote
Old 10-10-2012, 08:12 AM   #2
Rewards Points: 154
zone sizing
You need to find the data for the brand of Mini-Split that you are interested in purchasing. Most of the Mini-Split manufacturers recommend around 400 sf/ton.
Patrick Eubanks is offline   Reply With Quote
Old 10-10-2012, 05:54 PM   #3
Rewards Points: 266
Mini split sizing is no different than determining the heat loss or gain for a conventional ducted system. You need external temp, humidity, insulation, windows, bodies,.... Enter the variables and do the calculation.
ionized is offline   Reply With Quote
precharged split system heatpump servantforHim HVAC 5 02-06-2015 08:11 PM
Carrier System Sizing & Advice tballer HVAC 9 09-28-2012 06:25 AM
mini split efficiency rwfegley HVAC 10 01-14-2012 01:07 PM
mini split BTU question... newbieowner HVAC 13 05-31-2011 10:57 PM
Split System Line Set Sizing yogi_bear_79 HVAC 5 04-18-2011 09:18 AM
