Mini Split System New Electric Line From Breaker - HVAC - DIY Chatroom Home Improvement Forum
Old 09-18-2010, 09:22 AM   #1
mini split system new electric line from breaker
installating a new mini split and running new electric line for 1.5 ton condenser can the wiring be 10/2?
dawncass46 is offline   Reply With Quote
Old 09-18-2010, 10:28 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what does the unit list as max OCPD and minimum circuit ampacity?
That is what will determine what minimum size conductor you must use.
Old 09-18-2010, 10:53 AM   #3
An old Tradesmen
Rewards Points: 7,400
Provided the run is less then 500 foot long, no problem with 10/2 with ground.
Old 09-18-2010, 12:57 PM   #4
Rewards Points: 1,216
Follow the installation information included with the mini.
I just installed a 12, 000 BTU the MAX circuit size was 15 with 14 wire.
That's what it stated.
COLDIRON is offline   Reply With Quote
Old 09-18-2010, 01:04 PM   #5
An old Tradesmen
Thats the max breaker size. Nothing says you can't run a 10 gauge wire to it(well, the disconnect).
Old 09-18-2010, 01:31 PM   #6
I understand that you can do that it just seems a little outa sorts running 10ga on a 15 amp circuit.
I do follow your point. Of course it depends what's on the truck and how much time and distance you are from the supply house. yada yada yada.
Like building a mosque it's legal but should it be built.
Old 09-18-2010, 01:35 PM   #7
An old Tradesmen
Lots cheaper running 10 gauge then driving an hour to go pick up 12 or 14 gauge.
I'll stay out of the political view.
Old 09-18-2010, 04:14 PM   #8
Thanks been I value your opinion. I also hate politics I guess that was a bad analogy. #10, 12 14 will do for me. as long as I got that 15 a protection.
Old 09-18-2010, 04:49 PM   #9
An old Tradesmen
Sometimes. You think you got X foot of X gauge wire on your truck. Only to find out that your a few feet short if you try to use it.
If a supply house is 15 minutes away, not a big deal to go get the smaller size wire. If your an hour away. Ooops.
Then a larger gauge is less extra cost then the gas or time.
Other then that. It is a waste to use a gauge 2 sizes bigger then what the unit or length needs.
Split System Replace, Resell? golddog HVAC 3 06-25-2010 03:38 PM
Electric furnace makes loud noise like a breaker when it starts?? epyke HVAC 5 10-13-2009 05:03 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Line set size for Central AC JoeFL77 HVAC 5 05-21-2008 09:23 AM
Electric Line Under Ground Crazy Legs Electrical 9 04-15-2008 10:07 PM
