Mini Split System 110 Vs 220 Volt - HVAC - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 09:06 PM   #1
mini split system 110 vs 220 volt
I have noticed that some one zone units (12000btu) will come in a 110volt or a 220volt . Which one will give the best performance?
Looking to buy one
jhcjr is offline   Reply With Quote
Old 06-07-2012, 09:16 PM   #2
Rewards Points: 380
Not much difference in performance. Obviously less amperage draw on wire using 220, may be better with longer lengths of wiring from panel etc. Both should give rated cooling capacity.
If your panel has open spaces to use 220, that would be my choice, but others may have other opinions.
HVACDave is offline   Reply With Quote
Old 06-07-2012, 09:20 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
Get a 220V unit.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-07-2012, 10:33 PM   #4
Rewards Points: 616
no difference..... wire size that's all...
carmon is offline   Reply With Quote
The Following User Says Thank You to carmon For This Useful Post:
Missouri Bound (06-07-2012)
Old 06-07-2012, 10:41 PM   #5
Missouri Bound's Avatar
Yep! That's it.
Do you want it your way or the right way?
Old 06-08-2012, 12:48 PM   #6
Rewards Points: 242
yep 220v. the electric co charges for usage. the amps will be less and if you have a Demand Meter the 110v will hurt you in the wallet
hvac instructor is offline   Reply With Quote
Old 06-08-2012, 01:41 PM   #7
Plus, with 220v you have half the amps in the wires so you have 1/4th the power dissipated and wasted in them.
12w or so? Whoopee.
Old 06-08-2012, 08:36 PM   #8
Thanks for the info that helps alot....
Old 06-08-2012, 09:12 PM   #9
What???
Old 06-09-2012, 01:23 AM   #10
You pay by the watt...a watt equals volts X amps
220v x 10 amps = 2200 watts (2.2 kw)
110v x 20 amps = 2200 watts (2.2 kw)
Same amount of wattage, same power consumption, same everything...
wheelsup is offline   Reply With Quote
Old 06-09-2012, 03:24 AM   #11
An old Tradesmen
Rewards Points: 6,892
Yep. Higher voltage simply allows a smaller wire size to be used for the same size load.
Old 06-09-2012, 03:53 AM   #12
Rewards Points: 242
true. like i said if you have a demand meter the electric company will charge you more if you go over the amp draw. they give you a lower rate, but if you go over a certain amp draw then they charge you a higher rate. it works pretty good if you dont turn on the a/c, dryer and stove at the same time.
Old 06-09-2012, 03:57 AM   #13
An old Tradesmen
Around here. All demand meter rates are determined by KWH draw, not amps.
Old 06-09-2012, 09:37 AM   #14
Originally Posted by Missouri Bound View Post
What???
Some power is lost in the wires. If you have 1/4 ohm of wire resistance you have 25W lost if 10A is flowing, P = (I^2) R.
With 20A you'd lose 100W.
Old 07-25-2014, 11:02 PM   #15
I've never seen 220 volts with a 10 amp breaker....?
ronn287 is offline   Reply With Quote
Mini Split for heating in cold climate landev HVAC 9 01-29-2012 10:18 AM
Mini Split HVAC Question Shanems10 HVAC 1 02-04-2011 08:39 PM
Celiera Mini Split Error Codes cboyladd HVAC 0 03-29-2010 10:15 PM
Wiring Scheme for Mini Split A/C dmcclur3 Electrical 3 01-20-2010 09:01 PM
Mini split Slimbad HVAC 1 06-28-2009 07:21 AM
