Old 04-10-2012, 12:15 PM   #1
Mini Split Sizing Question for Winter Heat
I'm interested in installing a ducted mini split system, likely a Mitsubishi Mr. Slim, and I had a question in regards to sizing.
First, let me state that I live in Albany, NY and my outside design temperature is negative 1.
The MXZ-3A30NA unit is normally rated at 28,600 btu for heating at 47 degrees. At 17 degrees, it is rated at a maximum of 18,800 btu.
The 18,800 would be below my minimum BTU for the house.
What is normally done in situations like this, upsize to the next size compressor--the MXZ-3A36NA which can output 24,600 btu at 17 degrees, or add a supplemental heating system?
toddmanqa is offline   Reply With Quote
Old 04-10-2012, 12:22 PM   #2
Heat pumps just do not work well in cold areas. The back up coils would stay on when it's really cold.
Tags
btu, ducted, mini split, supplemental, winter
American standard heat pump question. SS laser HVAC 5 01-04-2012 10:35 PM
question about heat pumps in va (newbie question) jayk2k3 HVAC 2 12-20-2011 08:31 PM
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 06:38 AM
Mini Split HVAC Question Shanems10 HVAC 1 02-04-2011 09:39 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
