Mini Split Self Diagnosis Function "E4" - HVAC - DIY Chatroom Home Improvement Forum
Old 07-05-2009, 03:44 PM   #1
Mini split self diagnosis function "E4"
I have a 12000btu mini split ac unit. Hooked everything up system ran fine for about 24 hours, but unit then turned off and flashes "E4". Manual states that this means abnormality of outdoor unit, but that's all it says. The unit still cuts on and off and will work for about half an hour before cutting off and displaying "E4".
Any help trouble shooting this issue would be greatly appreciated. Thank you.
igotshocked is offline   Reply With Quote
Old 07-05-2009, 04:16 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
And what might be the brand and model of mini split system you have?
The Following User Says Thank You to Plumber101 For This Useful Post:
construction1 (05-21-2010)
Old 07-05-2009, 09:21 PM   #3
The outdoor unit and a Chigo, and the indoor unit is a toshiba. Model #'s on the manual are: KF-35GW/GX1b and KFR-35GW/GX1b
Old 07-05-2009, 09:50 PM   #4
An old Tradesmen
Rewards Points: 6,592
For what a Chiga cost. You should have gotten the matching indoor unit.
You might have burt out something in the outdoor unit.
Send it back and get another one, and order the matching indoor unit also.
Old 07-05-2009, 10:02 PM   #5
Are you saying that there is no fixing this one? It seems to me it should be something simple if I could isolate the problem vs. replacing entire unit.
Old 07-05-2009, 10:12 PM   #6
Rewards Points: 560
Took alittle while try this link
http://www.chigogroup.com/en/admin/S...3611345602.pdf
I'm guessing control board issues
Can you say CHINA...I had to install china for explorer
Old 07-05-2009, 11:14 PM   #7
Thank you! Hopefully this link will help, I will keep you posted.
Old 07-06-2009, 11:44 AM   #8
I'm unable to check the low pressure is normal while running, not exactly sure how to, and doubt I have the correct tools.
Everything else looks fine...
If the capacitor was bad, would the unit still turn on and run for awhile?
And if I had to go about getting the electric box or capacitor myself, how would I do so. I have the part #'s but can't seem to find where to purchase one from.
I bought it from ebay and they people I bought it from are not working with me very well and it seems I'd be better off getting the parts myself if I could.
Old 07-06-2009, 07:25 PM   #9
Rewards Points: 560
A little trick with EBAY
When paying for an item use a credit card. That way when you don't get a response call the card company and dispute the charges. This will get you a response quick, fast and in a hurry.
I have had to use it a couple of times and when the sell gets a charge back and you have the item they are more than willing to talk.
Keep us posted
Old 07-06-2009, 09:37 PM   #10
HVAC / Plumbing
one of the down sides not buying from an A/C contractor... No support when you need it.. I get those calls all the time.. My A/C is broken It's only a few months old.. I ask , Did you call the installer ?? No, I bought off the net. & they won't help.. My response. Sorry
kenmac is offline   Reply With Quote
Old 07-06-2009, 09:47 PM   #11
Rewards Points: 560
My response is cha-ching..$$$$
Old 07-06-2009, 09:52 PM   #12
stupid gook made sh1t
Why didn't the idiot get a matched evap...
hvaclover is offline   Reply With Quote
Old 07-06-2009, 09:55 PM   #13
Rewards Points: 560
do-dadodo do-dadodo YOU have just entered the Twlite zonE
Old 07-06-2009, 09:56 PM   #14
Lesson learned, credit card will be in use next time I make a big purchase such as this.
After looking at the inside of the outdoor, there isn't much to it; fan, motor, capacitor, electric box, compressor and some wires. The fan works when I turn it on as well as the cooling. This cancels out the compressor and motor. So seems to me by replacing either the capacitor or electric box or both. Is this thinking correct or am I way off.
Additionally, if my thinking is correct is there any way for me to check whether the electric box or capacitor is good?
Old 07-06-2009, 10:00 PM   #15
An old Tradesmen
A Chiga mini split is not a big purchase.
They are THE CHEAPEST unit on the market.
I use to sell then, I know what they cost, for a complete unit.
Mini split Slimbad HVAC 1 06-28-2009 08:21 AM
mini split install bmancanfly HVAC 1 06-01-2009 04:57 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 10:33 PM
Mini Split BillyD HVAC 4 06-14-2008 03:23 PM
