So I have spent weeks with HVAC contractors coming out and quoting a mini split system for my home. I use window units to cool in the summer and a 100 year-old oil furnace (exaggerating) to heat. So something better has to be put in place as the oil burner is like burning cash.
I received 3 quotes from $18 600 to $23 000 for 2x3 ton systems as that is cheaper than a 5 ton plus a single unit. However, I was outraged and refuse to pay that much so here is my new plan. I will purchase the system by myself and have a certified HVAC installer hook it up.
I settled for the LG series and was about to find it online for a very decent price but noticed something odd on the homepage of the dealer (good reputation and reviews. don't want to name the site cuz I don't want to seem like I am advertising for them)
Anyways, if you look at the picture you will see that the system is advertised as a 33 000 BTU with a 21 SEER rating. However, the description of this system states that the condenser is a 24 000 BTU and the LG picture wall unit is only 16 SEER. So how does that ad up to 33 000 BTU and 21 SEER?????
PLEASE help me out on this one. I want to go ahead with the purchase of 3 tri zone units and already found a certified HVAC installer for a good price.
I was able to cut the price of EVERYTHING in half and will come out around 9k all together instead of home depot's outrageous 18 000 for an old mitsubishi system. :vs_karate:
can't answer your question about mini-splits, but here's some food for thought:
1. You say you have an oil burning furnace. Is it forced air, hot water furnaces are referred to as boilers.
2. You say the house is 100 years old and the energy costs are high. This house could have very high heat loss; you sure the mini-splits will cut it?
3. SEER is for cooling, you have to look at hspf for heat. Also look at cold weather capacity, like 17f and below.
4. Have you looked into ways of fixing up the house to reduce heat loss? What you can do will depend on the house and budget.
5. Got natural gas available? For half of what you're about to pay for mini-splits, you can get a high efficiency gas furnace put in. With the mini-splits you'll still have to keep and maintain the oil burning furnace for backup if the heatpumps don't keep up.
Thanks for your reply. My furnace is a boiler with radiators and is over 20 years old. The unit on the pic goes down to 14f. I looked at all the options. No natural gas close by and I would have to go ductless for upstairs anyways because of the layout of my house. I am sick and tired of cooling in the summer with window units due to several reasons. It caused me water damage before and they eat up a lot of electric. On top of all of that they are unsafe for a single female household. We had car break ins in the neighborhood and the frist thing the police said to me when they paroled my neighborhood was "get rid of these window units"
9k for a full cooling and heating system is a lot cheaper than having central air installed AND replace the boiler. I used to live in Japan and I am a big fan of mini split.
Please correct me if any of my statements are incorrect. I am new to all of this.
p.s.the house is old but the windows have been replaced and it is well (not top notch) insulted.
In the next couple weeks on two homes I'm replacing two systems purchased online. As an engineer, I know my systems, but I anticipate making mistakes.
Even with seemingly matched units, these are not plug and play assemblies. If something is amiss, you made the choice and you're stuck with the problem.
Most contractors will not entertain owner bought equipment. If the owner made a mistake, no one can be made happy. The contractors that do install owner gear also don't float funds between equipment purchase and customer payment - or can't float funds.
From the questions you're asking, I suggest you learn more so that you can better assess contractors and find one worth building a working relationship.
As to your advertisement, that's a two ton system. Note the period. The three wall units cannot all run at the same time. The three wall units provide independent control of different rooms for a two ton total load by operating in sequence. But, the load is the load and if you need five tons, that's what you need.
As to the certified installer, why can't they take complete responsibility including purchase? I can't imagine they pay more for the gear and for the cost of their effort, you'll have a correctly sized and matched system.
Have you checked if natural gas is available from the local utility company? If available, utility bills will be less than oil or heat pump. - Ok no gas.
Looking again at the $3K system and $9K total, the price for replacing our three ton system was about $6,000 including the system. I anticipate the equipment cost should be 40% to 50% of the total cost. Six grand to set one box, hang three more, run three sets of pipes and three sets of wires seems a bit much. Does he include a licensed electrician for the power wiring?
Please keep in mind, if you air condition more of your house than you do now, your electric bill will likely be same or more even with more efficient units.
The quotes that I got from installers who would include purchase plus install all started at $18,000. Home depot even used mitsubishi units for the estimate that are discontinued. A lot of contractors here inflate the estimate because MD is on a mini split high. I can get the system for 6-7k. 11k for installation is outrageous!
The plan was to purchase 2 of the systems on the picture and place each on one side of the house. I need to heat 1500sq.
Please correct me if I am wrong, but are you saying that the 3 wall units will not be able to run at the same time with the 24000 BTU condenser displayed? Could I run the three units at the same time with a 36000 BTU condenser? Or what about a 54000 BTU and run all 5 units off the one 54000 BTU condenser and get one unit for the bedroom separately? It is on the other side of the house and not easily connected to the 5 ton system. Also, would you agree that the SEER rating for the 24000BTU condenser and the 3 units on the picture are 16 SEER and NOT 21 SEER as advertised in the header of the picture?
I attached a new pic that would work better I guess.
Believe me. I researched this day and night. I did not go into all the technical details, but pricing and performance. The installer would charge $3000 to hook up the units that I purchase from the site. The site is actually quite nice. It is certified by all major brands and a google trusted store. It lists installers who are HVAC certified and willing to hook up systems purchased from the site.
This way I will pay 6000k for the system and 3000k for the installation...
any input?
ps. how do I know how much SEER a unit has? is there a way to calculate it based on BTU or do I have to trust the description?
user12345a
why do I still need to burn oil? I was told that a good heat pump mini split will do in MD where winters are snowy but relatively mild.
Wasn't looking at climate - how cold can it get at night?
You should have a load calculation done and see if the heatpumps will cut it at design temp - nearly coldest ever experience.
You still may need to burn some oil. You could always do something like get an electric boiler for backup, but would need a 200 amp service. that or baseboard heaters.
winter average temp is 34. I will keep the radiators as a backup. also, the units range between 8-11 hspf. what does that mean? it has auto-defrost control as well.
hspf is equal to delivered btus divided by power consumption, wattage in heating mode delivered over the entire season based on lab tests.
For central systems the hspf is a function of the indoor coil used, condenser and air handler.
For the ductless splits I have no idea how the ratings work, if many different heads can be matched to one condenser model.
The most important aspect is how the unit maintains capacity as the temperature drops outside, since the idea is to burn as little oil as possible.
I would take a 8 hspf unit which maintains it's output well to 0F than a 11 hspf one which starts losing ground much sooner and shuts off at 10f or something.
2 Mitsi 3 ton inverter heats pumps(heat down to 4°F as I recall) with 3 indoor cassettes each(total of 6). Cost about 12 grand online(give or take a couple hundred varying on which online site is used, and whether or not tax is paid). No line sets, electrical equipment/material, no slim duct to conceal the line sets to keep the outside of the house looking clean and nice.
So throw 25% mark up(not much of a mark up) on that price, and you have 15 grand for the units alone. Throw on 2500(includes mark up) for the rest of the material for the install, and your at $17,500.00, and then add in 3 days labor, maybe more depending on how the lines have to be ran. 23 grand isn't much for the job then, since it would include a parts and labor warranty.
Bob...I wish I wouldn't be. If you search on google you will find many other folks who posted similar estimates. It's a rip off. Ridiculous. Really...
So people recommend to buy the systems and just pay for installation. That's why I am here :wink:
3 days labor? Nah. I would expect a system complete with duct work to be cheaper than $23,000 and there is no duct work in minisplits and they are not complicated devices to install.
You would have to do a load calc to be sure but I would be stunned to hear a 1500sqft house needs 6 tons in 34 degree temperatures. I have 4 tons for a just a bit under 1500ft and it works fine at 34 degrees.
Could I add another unit and make it 6 units that would run off this system? close to 5 ton just in case it gets a bit colder should be more than enough after reading your post.
You can get the mitsu systems starting at 5.5k. I compred apples to apples and used the estimates to compare units to a retailer and eneded up at 8k. So 10k is outrageous IMO for installation, even with the added costs of lines and wires. Please correct me if I am wrong...
LG IMO is just as good as the mitsu and even has better SEER ratings. Warranty is 7 years vs 10, but well...for a few k less I'm willing to risk that
Money is the object for a lot of people but in my experience a GOOD long term reliable HVAC company has a vested interest in keeping you for a customer and may do better work than some Joe in a Pickup you find to slap it in. There are fine details like proper leaking checking of the freon lines and using a proper micron gauge to pull a vacuum on them with. That is time consuming and expensive. Joe is in it for a few quick $$ and that is it. Won't ever be back or could not care less about doing a proper vacuum etc. Why would he? In his eyes you are taking away some of his profit and $$ by buying it yourself so why should he care about moisture in your system. As a tradesman I would feel the same and would just do the minimum too. You do pay more but get a warranty. It can take several days if you have plaster walls etc as they cannot be damaged or he is on the hook. Nobody on the net has seen your job or can tell you how long it should take.
And price defines a good hvac tech from a bad one?
Again, mini splits are not complicated devices to install. Homeowners can indeed do most of the work themselves and have an hvac tech do the last minute checks/vacuuming if you wish. It's not rocket science. Here's one through with a concrete wall install.
Minis are very technical and fragile. They must be selected, sized, and installed per manufacturers instruction, by trained techs, or you'll be plagued by problems. We had a unit that was misinstalled last winter by a contractor with no training and who didn't follow instructions. The whole system had to get ripped out and replaced. The manufacturer did not warranty the problems, nor should they have as the problems were not their fault.
She is talking about getting it installed not doing it herself. Totally different topic.
Price does not decide a good contractor. Reputation, referals from friends, BBB report and doing research to find one does.
However men like women have feelings and can be snarky, catty, mean spirited, back stabbers etc. No contractor I know of wants to install a unit they did not sell as they can make more $$ with their own sales. In general a guy who will never see you again has no interest in doing more than the minimum. There is no Maytag man. That was Gordon Jump an actor. In the real world you will get a better job from a concerned contractor. Not to say there are not bad ones but in general it may be better to go with someone who cares about his reputation and wants to have a customer. Plus you get a warranty.
If Joe P (ickup guy) does not pull a proper 500 micron vacuum and you end up with moisture then it will ruin the unit. Now if Bob wants to tell you how to stand over his shoulder and watch him do every procedure that is fine by me.:wink2:
Then that is a contractor which should be avoided.
Contractors are nothing more than tools people use to get the job done. As soon as your tool starts dictating the rules, then it's time to throw it away and buy a new one.... LOTS of them out there that don't come with this kind of ego. We hire LOTS of contractors and they play by OUR rules or they go find work someplace else. Now if we do supply the parts then we don't expect certain parts of a warranty to be honored by said contractor, but that's on us.
We have no room for contractors with ego issues or contractors who want to make huge amounts of money for nothing more than the mark up and the resale of parts. A contractor can be hired for install only or for both supply/install. There is no rule on the subject.
Do not go with the 8 instead of the 11, low temp capacity is a totally separate issue. Was just saying low temp capacity is more important than heating efficiency, they aren't correlated!
In theory no one should have to do that, but it's often necessary these days to refrigeration work properly.
How many contractors use a micron gauge? How many flow nitrogen when brazing? How many actually monitor refrigerant line temps to actually see what's happening in the system vs just pressures?
When we sell equipment, all of them do these things or they get failed on the equipment inspection. On my commissioning forms I have to do all these things or I get failed and run up the flagpole.
How should I know. Everyone I know does. My company does. If we get a unit with an acid burnout 2-3 yrs later and have to charge the customer $600-$1000 labor to change the compressor and they go on the net at DIY chatroom and Yuri says they did not use a vacuum gauge they get suspicous we won't have that customer.
The real money is in keeping your customers and selling them maintenance contracts.
Few contractors care and if you're paying, it's important to make sure things are done right. The contractor installs and collects the money, then leaves. You're stuck with the result.
There are probably a few good contractor in hvac, most of them probably being old and near retirement back from a time when people actually had a passion for this stuff. (...lots of them are old who don't do it right)
Had a really old, experienced guy a long time ago, I didn't know it at the time, but did everything by the book, put all the readings on the invoice, really cared and was thorough. Would pull a blower, pull pilot assemblies to clean, oil motors etc without even being asked just as the standard thing on a maintenance.
I've also witnessed (not for me) a contractor with perfect reviews on every site, a+ BBB do the minimum to get the equipment running, doing stupid things like running a new thermostat cable with enough wires but not connecting the common, leaving the t-stat at factory default settings (6 cph on a properly sized 2-stage furnace), leaving the cooling fan speed set to 1500 cfm or so for a 2.5 ton a/c.
The reviews are great because homeowners don't know if a job is being done properly, just if it works, is neatly done, and if the salesperson/installers were nice.
Bob works for the Government of Manitoba. That is a whole other world than residential HVAC. The standards are different and some HVAC contractors like working for the Gov of MB as they pay on time and it is a good contract to have. Instead of whining complaining people who don't pay their bills, find prices on the net and want everything for nothing.
Point being I have worked with 1000's of tradesmen from HVAC guys, plumbers, electricians, elevator contractors, controls people etc etc and guys are pretty much the same. Alpha male types. There is no fuzzy bunny nicey nicey Maytag world of HVAC Pro's. Everyone is in it to make as much $$ in as short a time as possible. Why should I care about Girly's system when I know she is trying to circumvent the system and lessen my profit. Because I am some Maytag guy that does everything by the book. Seriously if you believe that I got some prime farmland near Thompson to sell you.
If you get a contractor who is self employed and has a good reputation from people you know or a good referal in general you stand a much better chance at getting the proper job done. Joe P has no interest other than money. Like I said it is a chance but your odds are better with a good referal contractor than some Dude who may have a bad attitude because of the money issue. Contactors hate the net and people getting prices on parts and units. Why would they not. That is just human nature.
The things you say are every customers' worst nightmares and the reason why customers always feels like they are getting ripped off. Because people like you simply do in fact rip them off. Your "squeeze every penny possible" tactics might have worked 10 years ago, but you will find that with yelp and google plus your business will decline over time. The net is full of costumers who write reviews and warn other customers about contractors like you. How do you think did I get the idea of buying the units and just pay for the installation? I read reviews of people online who received outrageous estimates from people like you. And it might be hard to believe, but the guy that will do my installation is happy with the 3k he will walk away with. Not because he has no other costumers. Oh no. In fact I have to wait because he is too busy right now. Nope. He is just cool with making honest and easy 3k. No rip off. No hidden fees. No selling outdated equipment for double the price. Some folks are simply fine with making good money in an honest way rather than making triple with deceit and lies.
That's what happens when people don't have a passion and don't care. Corrupt society if you ask me but the way it is.
Just goes to show how necessary forums like these are. The only way to not get hosed is to to get independent advice free or hire a consultant/engineer who doesn't sell the equipment.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
