Mini Split Low Side Pressure - HVAC - DIY Chatroom Home Improvement Forum
Old 07-09-2009, 05:35 PM   #1
Mini Split low side pressure
I'm trying to maintenance a MSY-17NA Mitsu Mini Split... does anyone know what the low side pressure should read for this unit?
bronzbeard is offline   Reply With Quote
Old 07-10-2009, 10:53 AM   #2
there is no specific reading
I realize that the pressure depends on a number of variables... just looking for some general pointers/advice on what readings should be acceptable or unacceptable...
Old 07-10-2009, 11:27 AM   #3
What type of maintenance are you doing?
jerryh3 is offline   Reply With Quote
Old 07-11-2009, 11:40 AM   #4
im just checking to make sure the unit runs properly... if there's a leak somewhere i'll be adding r410a after i fix it
Mini split lineset question jerryh3 HVAC 48 04-06-2010 02:28 PM
Mini split self diagnosis function "E4" igotshocked HVAC 16 07-06-2009 09:03 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
well pump wont hold pressure jakjkl Plumbing 6 12-20-2008 09:11 AM
