Old 07-17-2009, 09:52 PM   #46
hvaclover's Avatar
Originally Posted by Home Air Direct View Post
There is no doubt that you have a lot more at stake than a couple of hired wrenches when it comes to your home. There is no reason that you could not have done everything, including setting the outdoor unit, hang the air handler and run the lineset to your specifications (sans hook up and start up).
Sounds like the weak link in your project was the pros in this case. That is a shame. Just make sure and vote with your voice. If you get an opportunity to advise someone about the service and quality that you did not receive, let them know.
In defense of the sweating, that has been one of my biggest issues with the ductless heat pumps. The linesets sweat. But that is no excuse for the pictures you sent. I have a cat that could have done a better job than that.
That sounds like a shameless plug for your business
Just slow, not stupid.
hvaclover is online now   Reply With Quote
Old 07-17-2009, 10:53 PM   #47
Yes. Looking back, I do regret not doing it myself. I could have purchased all of the equipment for around 5K. Another 5-6 hundred for a gauge set, vacuum pump, and flaring tool and I could have saved myself a few thousand. Plus, I know it would have looked a lot neater than this. The lineset that I'm realy having trouble with runs up when it exits the house and goes up through the sofitt into the attic. All of the condensation is dripping down these lines and traveling into the wall. However, if they would have made the insulation connectinos airtight like they should be, the problem could have been mostly avoided.
jerryh3 is online now   Reply With Quote
Old 07-30-2009, 04:09 PM   #48
Part three:
Update. The company sent out another crew. They pumped down the system and removed all of the inside units. They installed wall sleeves in the wall penetrations. They wrapped the linesets and drain line in cork tape from the inside unit to the K-Flex insulation. They cut out the tape joints and used contact cement to connect the pieces of insulation together outside. And, they repositioned the wall plates correctly to take the stress of the condensate lines. They seem to drain a lot better now and I haven't seen any problems with the lines sweating. This seems to be the only big mistake this crew performed. That's what happens when you don't properly prepare a plumbing joint.
More On This Topic
Tres Tew here, I'm an instructor at Yshua's Ryu Martial Arts on behalf of Expert Village I'm going to be showing you how to use your jacket or your hooded sweat shirt in a defense situation. I'd like to talk to you a little bit about using your jacket or... Read More »
When choosing to buy a helmet be sure that the helmet is not too tight around the face. Make sure that when you tighten the chin strap the helmet is secure but comfortable. If you can fit of two fingers side ways then the helmet is too loose.You should... Read More »
The Water Cycle
The Water Cycle by Expert Village
Now, to explain the states of matter one can bring up the water cycle. In the water cycle, there are the two states of matter represented. You can see evaporation and condensation. Now, remember water never disappears this includes any type of liquid... Read More »
Buying Hair Color Products
Buying Hair Color Products by Expert Village
Once you're decided what color process to do with your hair, whether you want to lighten, darken or cover gray, you have to decide where are you going to purchase your products from. Whether you want to purchase from a drug store, your general supply... Read More »
Learn how to tune a fender stratocaster electric guitar in this diy guitar setup video. Read More »
Mini split Slimbad HVAC 1 06-28-2009 09:21 AM
mini split install bmancanfly HVAC 1 06-01-2009 05:57 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 11:33 PM
Mini Split BillyD HVAC 4 06-14-2008 04:23 PM
Mini split heat pump...your expertise, please! ToniZ HVAC 0 09-05-2006 03:28 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
