Old 07-01-2009, 07:52 PM   #16
Most, if not all companies have a maximum length of a line set that can be used for a certain unit or for a multiple evap with one condensing unit. If you exceed it all warranties are void. They DO not recommend up sizing the line size. They are sized for proper oil return, cooling, and heating (if you have a heat pump). Post the model and serial number and I will see what I can dig up.
newtech is offline   Reply With Quote
Old 07-01-2009, 07:52 PM   #17
I don't mind the negativity. I like to hear honest answers. I know HVAC takes a lot of knowledge and skills and that's why this is the one project in my house I contracted out. The line sizes should be corrected tomorrow, now it's just the brazing part we'll have to address. I think I'm going to insist they extend the labor and parts warranty out to six years since they're not adhering to the suggested install procedures. If they say this is the better way to install it, let them stand behind it.
jerryh3 is online now   Reply With Quote
Old 07-01-2009, 07:54 PM   #18
old pro
Read my updated previous post about the StayBrite solder. That may be okay for you. Want to hear from Beenthere and the other guys about their opinion of it first.
Old 07-01-2009, 07:55 PM   #19
I have the install manuals for the outside and inside units and I'm within the max line lengths. It's only the sizing they messed up on.
Outside: MXZ-4A36NA
Inside: Three MSZ-A09NA and one MSZ-A15NA
Old 07-01-2009, 08:00 PM   #20
An old Tradesmen
Sounds like the sales rep your talking to, is for the installing company, not Mitzu.
Flare nuts made for refrigeration DO NOT crack.
And it isn't hard to learn proper flaring procedures.
Old 07-01-2009, 08:16 PM   #21
Yeah. The installing company rep brought up the flare cracking thing. The Mitsu rep said there's no reason to use brazing over the flares. He said correctly installed flares(correct cone length, torqued properly, etc..) should never have a problem.
Old 07-01-2009, 08:18 PM   #22
StayBrite is the best out there. Getting hard to find around here. Just don't know if I would trust it with 410-a. Used it many times on R-22 on TXV's.
Old 07-01-2009, 08:24 PM   #23
An old Tradesmen
The Mitzu guy is right.
The sales rep is making up a story.
Old 07-01-2009, 08:36 PM   #24
Ok. Damage control. The sales rep said they will reflare the inside unit's lines if that's what I want. I guess at that point they'll put a union to join the lineset to the inside unit. I saw the guy's flaring tools and their definately not anything high end or R410A specific. Should I go this route?
Old 07-01-2009, 08:51 PM   #25
An old Tradesmen
I'd prefer flares for it.
It it ever needs service down the road. You don't want to be paying for someone to always be rebrazing those lines.
I's also want the right size lines.
Old 07-01-2009, 09:00 PM   #26
They're bringing the correct size lines in the morning. We'll discuss the brazing verses flares then too. No matter what, they should not braze at the condenser, right? I don't even see how they could with this setup.
P.S. Like my dent? It hit so hard it bent the cabinet and that fitting rack. I think they dropped it getting it out the truck, but I got blank stares when I brought it up.
Old 07-01-2009, 09:07 PM   #27
An old Tradesmen
Dropped, or slammed it with something else.
They would have to use flare stubs to attach to the condenser. And then braze to the stubs.
Old 07-01-2009, 09:12 PM   #28
old pro
Beenthere is right. If you ever have to replace one of the indoor units it should have flare fittings. I would be concerned about them starting the wall on fire also. You are the customer and should insist on flared fittings. Not sure if they will have a good attitude after that but watch them carefully. The correct way to torque them is to put a bit of refrig oil on the flare and nut and tighten it, loosen it, retighten and repeat 3 times in total. This works the copper to the brass properly. Get the name of the district manager and quote it if necessary to get them to do what you want.
Old 07-01-2009, 09:15 PM   #29
An old Tradesmen
Should also use oil on the copper while you flare it. POE oil in this case.
Old 07-01-2009, 09:55 PM   #30
I hate this. I shouldn't have to tell an installer how to do his job correctly. It puts me in a bad spot no matter what. How hard is it to read an installation manual??? They couldn't even level the condenser pad correctly. If I knew if it was going to be this much trouble, I would have installed the unit myself. I can flip the switch on a vacuum pump. That's all there is to it, right?
More On This Topic
Hi, my name is Peter Gutwein and today we’ve been talking about some different minor repairs to your mower. The next thing I want to talk about is torqueing your head bolt down, especially on this style mower engine. The head bolt tends to loosen... Read More »
We need to move the stove out a little bit so that we can gain access to the back of it and what we're going to do next is take off the burner covers and take off this cover plate and then, if you can see, I can stick my hand through the stove here. And... Read More »
So the next thing you are going to do, is you're going to disconnect the flare fitting with something like this adjustable spanner, or adjustable wrench, also some people call it a crescent wrench. Put it onto the valve and turn it to the left, left... Read More »
Loosen the torqueconverter bolts by removing the dust shield to access the torque converter bolts when removing a motor from a car; learn how in this free auto-restoration video on cracked cylinder head repair. Read More »
Using Copper Sheeting
Using Copper Sheeting by Expert Village
OK, so I've been giving you a breakdown on the copper foiling as far as materials for your foiled glass project. We have gone through the black backed copper foiling, the regular copper foiling, the silver back. Also, there is a gold back and a brass... Read More »
Mini split Slimbad HVAC 1 06-28-2009 09:21 AM
mini split install bmancanfly HVAC 1 06-01-2009 05:57 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 11:33 PM
Mini Split BillyD HVAC 4 06-14-2008 04:23 PM
Mini split heat pump...your expertise, please! ToniZ HVAC 0 09-05-2006 03:28 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
