Mini-split Install Question - HVAC - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 12:45 PM   #1
DIY Homeowner
Rewards Points: 79
Mini-split install question
I will be installing a new ductless mini-split heat pump and hope to use the existing line set (1/2" & 1/4") since the new system specifies the same sized lines as the old one. The old system was only 4 years old, but after two control boards and a shorted electric expansion valve, I decided a brand change was in order. Old and new systems are both R-410a. Is there any reason to replace these refrigerant lines? Are there signs of contamination I should look for? The insulation is in fine shape and there were no leaks in the old system.
Also, these lines are only about 10 feet long. The new system comes charged for up to 25 feet. Any risk of an over-charge? Come to think of it, the old system was pre-charged for up to 50 feet of line. Might that have contributed to the bad EEV?
Thanks in advance.
BRO931 is offline   Reply With Quote
Old 11-29-2010, 01:37 PM   #2
HVAC Tech/Owner
Rewards Points: 604
Mini-splits are great when they work....I warn all my customers when they do break..$$$$$
Overcharge is a Killer.....do you have a vacuum pump? No issue with reusing the linesets as long as the compressor is not a burnout. Charge must be weighed in per the instructions (or weighed out for the difference)
Technow is offline   Reply With Quote
The Following User Says Thank You to Technow For This Useful Post:
BRO931 (11-29-2010)
Old 11-29-2010, 03:15 PM   #3
DIY Homeowner
Rewards Points: 79
Amen on the $$$$$ warning! It was going to cost almost $1000 to fix the old system which I bought for $1600.
Yes, I have a vacuum pump. I've installed two ductless systems so far. One is still going strong (fingers crossed). I do intend to vacuum the new system before releasing the refrigerant from the outdoor unit. It comes pre-charged. Once the system is evacuated, you just open the two valves on the outdoor unit and you're ready to go. The charge is adequate for up to 25 feet of line between the indoor and outdoor units. Any longer and you have to weigh in more R-410a. But the instructions say nothing about removing any if the lines are shorter than 25 feet.
The old system was pre-charged for up to 50 feet. Maybe that was too much refrigerant for my 10-foot lines. But over-charge is just a risk for the compressor, right? I had no problems there.
Old 11-29-2010, 03:20 PM   #4
HVAC Tech/Owner
Rewards Points: 604
No, its also a risk for the EEV, and probably why it failed. Too much refrigerant probably caused it to over compensate.
Old 11-29-2010, 05:44 PM   #5
IMO the extra 3-4 ounces of refrigerant isn't going to hurt the system. Half to 2/3rds that will be stuck in your manifold and hoses since most mini splits only have one access port. In reality it's going to be overcharged an ounce or two when all is done. Not worth messing with for that little bit.
Question: Can I Install Pergo over Dri Core? Starlight Flooring 1 10-01-2010 08:05 PM
Cultured Stone Veneer Install Question wifepleaser Building & Construction 3 05-01-2010 04:28 AM
mini split install bmancanfly HVAC 1 06-01-2009 03:57 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 09:33 PM
Mini Split BillyD HVAC 4 06-14-2008 02:23 PM
