Mini Split Install - HVAC - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 07:52 PM   #1
mini split install
I am installing a mini split ac unit. Confident with the install. One question
Do I need to add or remove any r-22 for length of the line set?
Edgertonskifish is offline   Reply With Quote
Old 04-22-2013, 08:09 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
Read the manual!!!!!!!!!!!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-22-2013, 08:32 PM   #3
An old Tradesmen
Rewards Points: 7,808
Install manual will tell you that. Each brand will have their own specs.
Old 04-23-2013, 12:57 PM   #4
When did you buy this mini split? The reason I ask is you can't buy a unit charged with R-22 anymore. They still sell R-22 units but they can't precharge them, they have to be sold "dry". Are you actually sure it's an R-22 unit? If so I'd assume it would be empty. (unless there's some loophole allowing them to sell R-22 mini splits I'm not aware of) In which case it definitely would need to be charged. But first i'd verify it even takes R-22.
JScotty is offline   Reply With Quote
Ductless Mini Split Install - need HVAC Tech! mike_30319 HVAC 18 04-04-2017 12:09 PM
Mini Split - wall or ground mount? vsheetz HVAC 9 04-07-2013 02:39 AM
mini split superheat rwfegley HVAC 5 02-19-2012 06:53 PM
LG Mini Split MS 36 AIR CONDITIONER Inlouof HVAC 5 09-17-2011 09:46 AM
Why does a ductless mini split need to be a minimum of 5' off the floor? jayp HVAC 5 09-15-2011 11:12 AM
