Old 02-04-2011, 07:41 PM   #1
Talking
Mini Split HVAC Question
I have just installed a new mini split Klimarie 3 zone unit
(KSIM30912-H216). My question is that when I put it in heat mode it started freezing up on the condensor but the inside units were pumping out very warm heat. I just wanted to know if this is normal it was in operation for about 30 minutes. The outside temp was 43 and the inside units were up on 82 just to check heating mode. The unit was pre charged for 25 foot and all runs are shorter than that. Any help would be great thanks
Shanems10 is offline   Reply With Quote
Old 02-04-2011, 09:39 PM   #2
Still Learning
Yes that is supposed to happen. Ductless mini splits are a heat pump which means that it is pulling heat out of the 40 degree air outside and sending it inside. When it gets too frozen it will automatically switch to defrost mode like a freezer.
thehvacguy is offline   Reply With Quote
general HVAC question wmmurphy HVAC 5 05-26-2010 12:50 PM
general hvac question dc21 HVAC 1 04-03-2010 01:03 PM
mini split install bmancanfly HVAC 1 06-01-2009 04:57 PM
DIY mini splits benjamincall HVAC 1 01-23-2009 09:44 AM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 10:33 PM
