Old 09-05-2006, 03:28 PM   #1
Question Mini split heat pump...your expertise, please!
I am considering installing a ductless mini split heat pump. House is located in southeast Louisiana, 59 years old, raised, 1400sqft, presently cooled with window units, heated with natural gas freestanding, unvented heaters. A local contractor (with good reputation) installs Fujitsu and Turbo Air. The Turbo Air would cost less, but I have found very little info about them (only their website info). Does anyone have any experience with Turbo Air heat pumps? Fujitsu heat pumps? Are the mini split systems as efficient as they claim to be? Thank you.
ToniZ is offline   Reply With Quote
More On This Topic
Balloon Folding: The Pump
Balloon Folding: The Pump by Expert Village
Hi, I'm Jeremy here on behalf of Expert Village. Talking a little bit about ways of pumping up your balloon. The standard way the way everybody expects you to do it is with your mouth. I personally don't like using my mouth cause I can blow about 5-6 and... Read More »
This is Sean for Expert Village. We're going to be talking about a 540 tire tap. Like I said to get speed go ahead and get to the other side of the mini do some kind of peg trick and that way you'll be able to get a good pump coming back. When you come... Read More »
In this clip we are going to apply color now to our mass of turbo cobalt. So basically I am just going to turn on the torch and we are going to take our silver striker here and we are going to make lines on it. Alright so we are going to want to go from... Read More »
For pumping of tires while on the road there's a few choices out there. One of them is a CO2 inflator; very small, easy to carry in a bag, somewhat pricey if you're using threaded cartridges. Every flat is going to run you a couple of bucks. You can buy... Read More »
Nothing can ruin your summer or winter like finding you have no heat or air conditioning because your heat pump is malfunctioning. If you have to buy a new heat pump, an uncomfortable season can turn into an uncomfortable year. However, heat pumps are... Read More »
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 02:27 PM
Getting a House..heatpump or no? DavidsCPU HVAC 9 11-27-2006 08:08 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 11:10 PM
heat pump dreck HVAC 2 09-11-2006 09:18 PM
heat pump not working kyleGR HVAC 2 05-30-2006 04:35 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
