Mini Split Error Codes????? - HVAC - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 03:10 PM   #1
Question
I have a Yonan mini split a/c unit. This is a dual unit that has one outdoor unit and two indoor wall mounted units. The model number to the outdoor unit is KFR-(35*2)W/BP. When I flip the circuit breaker on, the two indoor units run for about 60 seconds then shut off and flashes an error code of
"F-1". The outdoor unit never comes on. I have two questions. 1) Does anyone know what the F-1 error code is and how to correct it? 2) Does anyone know of a company that sells and services Yonan in the USA? The internet only has companies in China.
LSUConstructor is offline   Reply With Quote
Old 08-10-2012, 04:15 PM   #2
Rewards Points: 13,274
If you just Google the make and Model most often the manual with the codes can be found.
There's also a contact person listed on there web site, have you tryed emailing them?
Old 08-10-2012, 04:36 PM   #3
where did you get the unit from, if you are the one that got it ? Did you install or someone elese? I personally have never heard of that brand.
turnermech is offline   Reply With Quote
Old 08-11-2012, 01:04 PM   #4
Rewards Points: 77
Never heard of Yonan, possible a private labeled Chigo , Gree , or Haier - they make mini splits with anyone's name including their own
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
mini split efficiency rwfegley HVAC 10 01-14-2012 01:07 PM
Mini split in basement? Mills314 HVAC 1 07-04-2011 10:36 AM
mini split BTU question... newbieowner HVAC 13 05-31-2011 10:57 PM
Mini split heat pump for us? Cedrus HVAC 5 03-08-2011 10:47 AM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 10:33 PM
