Mini-split Clearance In Front - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2013, 06:45 PM   #1
Rewards Points: 248
mini-split clearance in front
Looking at getting a mini-split system for the ranch house. I am concerned about theft and want to install security bars around the outside unit. Only problem is that the installation instructions require 79 inches of clearance in front. Is this for air-flow or maintenance access? If it is for maintenance access I suppose I could tell the inspector that I installed a security bar gate that allows for access to the unit. The security bars are spaced 6 inches apart and let lots of air through. I can't see how air flow could be an issue with the security bars.
jackwashere is offline   Reply With Quote
Old 12-26-2013, 06:52 PM   #2
An old Tradesmen
Rewards Points: 7,826
Its for air flow. 6" apart should be fine.
Old 12-26-2013, 06:54 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 178
It is for maintenance only. You need about 3 feet clearance in front to get enough airflow thru. Try not have high shrubs within the 3-5 feet so the heat does not hit them and recirculate back into the intake and make it work a LOT harder and shorten it's life and use more juice. If the bars are removable he should not have an issue if you are there to explain them to him.
Old 12-26-2013, 07:28 PM   #4
Rewards Points: 6,652
If you have a local Metal fabricating shop, have them make something Ornate that will still protect the unit, but is not just a set of straight bars in front of the unit. What is the roof like for the building, or can you place it up high on the wall, that makes it difficult for someone to reach from the ground.
Keep in mind when you place the bars, that you are going to have to either use bolts in cement to hold them in place, or have enough length on the ends, to allow you to place the unit for the guard cage in concrete.
They do also make alarm sensors that you can attach to the units, to notify you when someone is messing around with it.
mini split install Edgertonskifish HVAC 3 04-23-2013 12:57 PM
LG Mini Split MS 36 AIR CONDITIONER Inlouof HVAC 5 09-17-2011 09:46 AM
Why does a ductless mini split need to be a minimum of 5' off the floor? jayp HVAC 5 09-15-2011 11:12 AM
Mini Split Systems singplumb HVAC 2 07-18-2011 09:09 PM
Installing a mini split ductless system agenkin HVAC 1 06-14-2008 09:33 PM
