Mini Split Choices Give Splitting Headache!! - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 11:31 AM   #1
pwa
mini split choices give splitting headache!!
Hi to all, I am thinking of having a mini split installed since I cant install one myself or even buy one online without voiding the warranty,if I understand correctly? Living in Idaho the temps are often in the teens or less.My space is 800 sq. ft. with probably a little more glass than average an pretty good insulation.I do have electric baseboards for back-up. My small town dealer is offering me a fujitsu aou24rlwfw. I am a little worried about some of the reviews I have read about them not doing well under 20 degrees.My dealer also sells Mitsubishi but says their not worth the price difference.My nearest Daikin dealer is 70 mi. away. Any help would be appreciated.Thanks
pwa is offline   Reply With Quote
Old 11-11-2012, 12:54 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
SO you're looking for a heat pump mini split? When it comes to comfort and reliability I'd be doing what you're doing, reading all reviews and judging from there. 70 miles for better equipment (if indeed the reviews state it better) isn't a big deal. I drive that far just to fill up my diesel truck.
You'll thank yourself when it's 10 degrees outside and 75 inside.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
pwa (11-11-2012)
Old 11-11-2012, 01:00 PM   #3
pwa
Its not that 70 miles is that far(in the summer anyway) I just figure that will really add to the install price and later on the service calls could get spendy.Everything breaks,its just a matter of time
Old 11-11-2012, 01:02 PM   #4
Rewards Points: 13,300
No heat pump works that well below 20 deg. It's the nature of the beast.
Once it get that cold the back up heat kicks in.
pwa (11-11-2012)
Old 11-11-2012, 01:02 PM   #5
read below.
Thanks.
pwa (11-11-2012)
Old 11-11-2012, 01:03 PM   #6
No room for a full residential hvac system? Attic or basement? I don't think any heat pump will be able to fully handle those types of conditions on it's own.
Thanks.
pwa (11-11-2012)
Old 11-11-2012, 01:04 PM   #7
pwa
Hey Doc, I seen on your profile your an hvac tech. Would you care to share some of your insight?What are your favorite manufactures of mini splits?
Old 11-11-2012, 01:10 PM   #8
I could but we don't get that type of cold in Houston and it's a heat pump you want, right? LG, Mitsubishi and Samsung would the brands I'd choose from.
Just like with regular residential hvac system manufacturers, brand is not important, install is.
Thanks.
pwa (11-11-2012)
Old 11-11-2012, 01:11 PM   #9
pwa
A ducted system would be very tough
Old 11-11-2012, 01:38 PM   #10
pwa
yeah, its the efficency of the heating that concerns me.I'm sure the colling will be fine and I hope fijitsu is on your list too?
Old 11-11-2012, 01:40 PM   #11
pwa
whoops- fujitsu
Old 11-11-2012, 04:01 PM   #12
raylo32's Avatar
Rewards Points: 1,240
I spent a winter in Idaho... saw temps down to -35. I can't imagine a heat pump being any use there.
Live long and prosper.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
pwa (11-11-2012)
Old 11-11-2012, 07:27 PM   #13
pwa
Like alot of states it just depends where your at. I have been here 10 yrs now and the coldest I have seen is -7.It only gets relly cold for short periods with 20's and 30's being the norm
Old 11-11-2012, 07:33 PM   #14
raylo32's Avatar
I guess that's the "warm" part of Idaho!
pwa (11-11-2012)
Old 11-11-2012, 07:57 PM   #15
pwa
how about "warmish"
mini split system 110 vs 220 volt jhcjr HVAC 14 07-26-2014 12:02 AM
Countertop - material choices giving me a headache hyunelan2 Remodeling 7 10-10-2010 11:36 AM
please give me feedback on these tile choices etc. dahlias987 Remodeling 3 01-01-2010 11:57 AM
This header give me a headache FrankC Building & Construction 1 11-18-2009 07:36 AM
Mini Split BillyD HVAC 4 06-14-2008 03:23 PM
