Mini Split BTU Question... - HVAC - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 09:37 PM   #1
mini split BTU question...
Hello all,
The previous owners of my house added a den that every HVAC tech said needs to be on its own zone since its next to impossible to run ducts to.
I am ready to install a mini split for this 132 sq. ft. room, I used an online calculator and it says this room needs 6,600 BTUs to cool it down. The lowest single room mini split I can find is 9,000 BTU.
Should I go with the 9,000 btu model?
How about this one: http://www.westsidewholesale.com/ls0...u=383831303730
newbieowner is offline   Reply With Quote
Old 05-30-2011, 09:43 PM   #2
Missouri Bound's Avatar
132 sq ft? Any chance you can put in a regular wall unit? It would be way way WAY cheaper, and do the job just as well. A through the wall unit is basically a window air conditioner with some slight modifications. A room that small just doesn't need a split system.
Old 05-30-2011, 09:51 PM   #3
I have considered shoving a wall unit in there. The wife on the other hand doesn't like "holes" put in her walls.
It is used as an office where she makes tons on phone calls and wants a quiet system in there.
Crap I for got to add this room has cathedral ceilings and the washer/dryer is in there which makes more noise than she likes and doesn't want to add more.
Hey she's paying for it so....
Old 05-30-2011, 10:01 PM   #4
I understand the reasons as you stated them. The split systems are very quiet. They do require 240V and a seperate disconnect outside. I personally would live with the noise, but keeping her happy may be well worth the added costs with the split system. Does that room require heat as well? Some of those systems have heating capability as well. Good luck with the project.
Old 05-30-2011, 10:22 PM   #5
the room has sufficient heating from baseboard running almost the entire length of the walls (overkill IMO). its not only the quiet she wants. It also the ugly look of a window from the outside.
So how's about that LG unit I linked? Yeah it should be a big learning curve DIY. But I am lucky enough to live across the street from a HVAC contractor and a licensed electrician. Both who will help for the cost of beer.
Old 05-30-2011, 10:47 PM   #6
The LG is a good unit. You may want to check out Mitsubishi, but I doubt those are that cheap. Does your HVAC neighbor have a reccomendation?
Old 05-31-2011, 12:07 AM   #7
He uses Mitsubishi and Fugitsu only. Too much $$$ imho
Old 05-31-2011, 12:48 AM   #8
Rewards Points: 1,016
I have a GE PTAC in my converted garage / hobby room. Works great, but is a bit noisy for a quite area or bedroom. Similar to the systems common in hotel rooms. I travel quite a bit for my work and find many of them noisy.
I plan to put a mini-split in a master bedroom addition this summer. The LG units seem to be of good quality and price. Agree, the biggie is the noise factor - for many units specs list the air handler noise level and some have an extra quiet setting. Many of the higher SEER units will now run on 120VAC rather than 240VAC.
Read through the installation instructions - all are pretty simple to physically install. And you have the ready availability of a HVAC tech to do the final bring up of the unit so you are home free.
Old 05-31-2011, 05:37 AM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,756
LGs are good. Try order a full blown troubleshooting and service and parts manual ASAP. Hard to get them a few years down the road and the models change frequently. The owners manual does not have the in depth service info a tech needs.
Old 05-31-2011, 03:03 PM   #10
thanks for the advise.
btw I was just sent this quote of $1265 for a Sanyo single zone 9000btu mini split 16-20 SEER variable speed.
it includes:
shipping
15' interconnecting lineset with UV wiring
service disconnect box and power whip
condensor mounting block risers
wall sleeve
warrantee, tech and installation support
good deal or just wondow dressing?
Old 05-31-2011, 04:31 PM   #11
Rewards Points: 1,216
Sounds like a reasonable price , go for it.
COLDIRON is offline   Reply With Quote
Old 05-31-2011, 07:12 PM   #12
Before you buy, check out www.alpinehomeair.com
Old 05-31-2011, 09:53 PM   #13
Are you affiliated with them?
thanks.
Old 05-31-2011, 09:57 PM   #14
Not at all. I was looking for furnaces that I could purchase w/o an HVAC company and found them that way. I can't give any positive or negative feedback, but the pricing looks good on most things.
Wiring Scheme for Mini Split A/C dmcclur3 Electrical 3 01-20-2010 09:01 PM
Mini split HVAC systems Homeflip HVAC 4 01-10-2010 11:25 AM
Split 3-phase mdwkailua Electrical 21 04-07-2009 01:55 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
