Mini Split AC Units BTU Output - HVAC - DIY Chatroom Home Improvement Forum
Old 05-30-2013, 02:40 PM   #1
Rewards Points: 874
Mini Split AC Units BTU output
From what I know a dual zone unit of say 16,000 BTU will put out ~8,000 BTU for each zone. If you are only using one zone will it out of the full 16,000? THanks
Mstrlucky74 is offline   Reply With Quote
Old 05-30-2013, 03:08 PM   #2
Rewards Points: 196
No, and not every system is split 50/50 .May be 10k and 6k etc...Each head unit has a compressor in condenser.Product data sheet should tell you what each circuits btu's is.
HVACTECH96 is offline   Reply With Quote
Old 05-30-2013, 04:00 PM   #3
Rewards Points: 874
THanks. That would be great because one room is larger than the other and I would like that room to have the greater output of BTU.
Mini split vs. duct-based systems - venting? sheslostcontrol HVAC 3 06-07-2015 04:15 PM
Mini Split - wall or ground mount? vsheetz HVAC 9 04-07-2013 02:39 AM
Mini Split Sizing Question for Winter Heat toddmanqa HVAC 1 04-10-2012 11:22 AM
Mini Split Systems singplumb HVAC 2 07-18-2011 09:09 PM
Mini Split BillyD HVAC 4 06-14-2008 02:23 PM
