-   -   Mini split (http://www.diychatroom.com/f17/mini-split-47636/)
Slimbad 06-28-2009 12:03 AM
Mini split
Hi,
I have a Fujitsu mini split AC and the condensor is installed on the roof. The roof will be redone shortly and I need to remove the unit for them to work. My unit is working fine, Can I unplug it and replug it afterward by myself? Do I need any special device like a vacuum pump or can I just disconnect the the tubes and reconnect and it will work again without problem?
Thanks for advice!
beenthere 06-28-2009 08:21 AM
Need to either pump it back to itself.
Or recover teh refrigereant.
Then vacuum the lines when its reconnected.
