Millivolt Gas Valve / Powerpile - HVAC - DIY Chatroom Home Improvement Forum
Old 10-17-2009, 11:29 AM   #1
Millivolt Gas valve / powerpile
Having trouble diagnosing the problem with the Gas Valve. I replaced the power pile with a 750mV unit and it produces a 625mV signal but the pilot will not stay on. Any suggestions?
electricwalt is offline   Reply With Quote
Old 10-17-2009, 11:49 AM   #2
625 mV is open circuit voltage?
What does the coil resistance of the valve measure?
Old 10-17-2009, 11:59 AM   #3
.4 K ohms TP and .39K ohms TH open circuit. 625 mV circuit complete
Old 10-17-2009, 12:06 PM   #4
xxxxxx
Old 10-17-2009, 12:51 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 100
Post a pic of the gas valve and pilot burner (where the pilot light burns).
Old 10-17-2009, 09:50 PM   #6
Houston204's Avatar
Rewards Points: 556
Whats up Yuri
You may need to describe what it takes to post a pic here. It's a little different than some other sites
Houston204 is offline   Reply With Quote
Old 10-17-2009, 10:00 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 100
Well, well well, long time no see from my old buds from HVACMech. Too bad the po*n spammers killed it. Glad to see you found us, wish TKG would also. There are instructions with the posting box (go advanced/scroll down to additional options/manage attachments)how to upload pics and they can post the links here from photobucket etc.
Welcome aboard, now you need to get to know some of the personalities here. After your post count gets high enough I will send you a private message.
Cheers
Old 10-18-2009, 04:44 AM   #8
An old Tradesmen
Rewards Points: 7,794
I would check for tripped safeties. Where are you measuring the voltage at.
Could be it was the gas valve that was bad, and not the generator.
Old 10-18-2009, 10:01 AM   #9
If the 750 mV doesn't drop under load, there is no current being drawn.
If it drops to 625 mV from 750 mV when it's under load you may be drawing ~40 mA.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Can I use a 750 millivolt generator on a 250 - 500 millvolt Gas Valve stanlam HVAC 36 10-14-2011 06:43 PM
Double Check Valve installation (and a few other questions) secutanudu Plumbing 0 04-17-2009 07:42 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
