Old 09-02-2007, 10:54 PM   #1
Default miller oil furnace not kicking on.......
Hi, well i fixed everything to keep the furnace running and going great but when the burner kicks on and begins to burn the fuel, the fan doesnt start until the burner stops when it reaches the temperature that it is set on the burner limit switch. is my fan limit switch faulty or is there something else that im not seeing?? other than that it will start and run but not start the fan until it reaches the temperature on the switch. then while the fan is running when the temp drops, the burner fires back up again. i was told the fan should start up no later than 20-30 secs after the burner starts due to the fact that i am losing heat out the stack. any suggestions?? heres a challenge for CARRIERMAN any answers or suggestions is greatly welcome and can e-mail me at ... jamwaves@hotmail.com if easier to explain or ask any questions. thank you for all and any help
jb9270 is offline   Reply With Quote
More On This Topic
The thermostat on your wall that controls your HVAC system is the key to your comfort. Knowing how it interfaces with your heating and air conditioning system can help you stay comfortable during long, cold winters and hot, sweltering summers. A key part... Read More »
Hi I'm Betty Ingham on behalf of Expert Village. We know that it's cone 9 and when cone 9 goes down we know that it is time to open the burners back up. When we open back all 4 burners that really shows that we are going to clean up everything. It is... Read More »
Everyone can benefit from using less energy in their homes. You save money each month on your power bill, plus you have the happy knowledge that you are helping the environment by making your home more energy efficient. If everyone did a few energy... Read More »
Next, let me show you what you need to do. Take this ingot, which is a blended lead alloy, lower this into the furnace, which already has molten lead in there, and let it mix within the lead. Be mindful of the temperature that you have this on. You don... Read More »
Hi, I'm Doug. I work with 20 great guys in St. Louis at Doug Jenkins Custom Hot Rods and we're going to do some work for you today on Expert Village. Now that Andy has shot the primer, the base coat, the candy coat and two coats of clear, we're ready to... Read More »
miller furnace problem cometcyclone HVAC 1 02-08-2007 09:27 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 04:04 PM
miller mobile home furnace wont keep running jb9270 HVAC 4 01-30-2007 12:12 PM
Miller Mobile Home Oil Furnace jjalba9 HVAC 1 01-22-2007 12:57 PM
Miller furnace led codes? dmiller33 HVAC 1 10-05-2005 01:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
