Miller Oil Furnace Dripping Oil - HVAC - DIY Chatroom Home Improvement Forum
Old 01-27-2008, 06:38 AM   #1
newbie
Question
miller oil furnace dripping oil
I have a 3 to 4 year old Miller furnace. I had it check because it was dripping oil. I was told that I might have to replace the front panels that the gun screws to because it warped and the tube is sloping out and when the nozzle drips it is running out instead into the chamber is this noted to happen? thanks John
skullrunner is offline   Reply With Quote
Old 01-27-2008, 07:26 AM   #2
Union HVAC Tech.
if you have nozzle drip the checkvalve in the oil pump is shot. it isn't normal to have oil dripping in the combustion chamber. You should add a solenoid valve to the nozzle line.
bigMikeB is offline   Reply With Quote
Old 01-28-2008, 05:13 AM   #3
Mainah's Avatar
the blast tube should indeed pitch down towards the unit- afterdrip can also be caused by some air in the fuel line, but it's most likely is what Bigmike said-
if replacing the nozzle and bleeding the line doesn't help replace the pump or go with the selenoid valve-
Mainah is offline   Reply With Quote
Old 01-28-2008, 12:23 PM   #4
newbie
Hi bigmike thanks for the info. Should I replace the pump and put in a solenoid valve or should I just by a new pump? I have another pump that got destroyed by grit can I take the check valve and replace the one in this pump? Do you have any idea what made the check valve go? Thanks John my email is johnny2941@yahoo.com
Old 01-28-2008, 05:56 PM   #5
Union HVAC Tech.
I would put in the solenoid valve first, then see how it works out. The valve will stop nozzle drip. The checks in the pumps go fairly often.
Weird Miller furnace issue Rugerfan HVAC 2 01-26-2008 08:31 AM
Miller Furnace Problems Ajournyman HVAC 8 01-16-2008 08:33 AM
miller mobile home furnace wont keep running jb9270 HVAC 4 01-30-2007 10:12 AM
Miller Mobile Home Oil Furnace jjalba9 HVAC 1 01-22-2007 10:57 AM
