Old 01-21-2007, 03:16 AM   #1
Miller Mobile Home Oil Furnace
I am having a problem with my furnace. It is an older Miller furnace in a mobile home. The furnace will run fine until it reaches the desired temp. After that, it will not kick back on unless I open it up and press the reset switch. Once I do that it will kick back on and run until it reaches the correct temp again. Do I need to clean my flame sensor, or does it sound like a bigger problem. If it is the flame sensor, is this something I can do or should I call in a repairman? How do I clean the flame sensor if it is something I can do on my own? Thanks for any help.
jjalba9 is offline   Reply With Quote
Old 01-22-2007, 11:57 AM   #2
Thoroughbred Mopar Man
Hi jjalba9
What you are resetting is the igntion watch guard. Have the piece of equipment serviced, this needs to be done by a qualified oil furnace technician, you don't want just anybody doing this. There is a list of things that have to be done to oil furnaces on an annual basis, if this is not done it can and generally will cause lockout problems.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
More On This Topic
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Hi, I'm Doug. I work with 20 great guys in St. Louis and Doug Jenkins Custom Hot Rods and we are going to do some work with you today at Expert Village. So the computer gets input from varies sensors from the engine. This tells the computer the angle of... Read More »
Hi, I am Tamal Bhattacharya speaking on behalf of Expert Village. After making my clay slabs I am ready to start the process for firing them. Prior to firing I will let my slabs dry naturally. This will take a long time and it will take even longer if... Read More »
A space heater can save money on gas and electric bills because it heats only a small area and efficiently converts almost all of its energy into heat. However, heaters can pose a serious danger from fire and toxic air pollution. Reduce these risks by... Read More »
If you're living in a mobile home and facing your first winter, you may not be aware how difficult it can be to keep a mobile home warm. Taking the proper steps to winterize your mobile home cannot only help keep you warm, but keep your heating bills... Read More »
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 40 02-22-2009 10:26 AM
miller furnace problem cometcyclone HVAC 1 02-08-2007 08:27 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 03:04 PM
miller mobile home furnace wont keep running jb9270 HVAC 4 01-30-2007 11:12 AM
Miller Mobile home furnace hiskid1973 HVAC 11 01-12-2007 09:33 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
