Miller Gun Furnace Won't Stay On - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2011, 11:46 AM   #1
miller gun furnace won't stay on
I recently bought this old trailer with a Miller MOC 80 furnace in it. It had been working fine, now it will come on if I reset, but won't stay on long enough for heat, blower won't come on. I am new this. I posted a question earlier "mac 80 problem" then realized I hadn't posted as HVAC. Sorry if this creates a problem. Could it be the nozzle -- where is it? or the thermostat?, or the flame detection mechanism? or ???
ranbb is offline   Reply With Quote
Old 11-05-2011, 04:01 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
is there a control board in it?
Doc Holliday is offline   Reply With Quote
Old 11-05-2011, 05:20 PM   #3
thanks for reply
I don't think so. It is old, in old trailer. Where would control board be?
Old 11-05-2011, 05:23 PM   #4
open the service panel. Look for where wires are going into the unit.
Old 11-05-2011, 05:29 PM   #5
This is a Miller gas furnace, it has a control board. Is yours anything like this? If so the board would be below blower compartment in metal box. You can remove the lid from said box.
Old 11-06-2011, 10:06 AM   #6
there is a small box w/2 blk, 1 blu, 1 red wire, a toggle switch for winter/off/smr - set to wntr, and a plate w/schmtc - I removed - numerous wires under it. All of the wires appear to be connected, not frayed.
Old 11-06-2011, 11:52 AM   #7
Take some pictures, please, of everything. Schematics, box, all wiring.
Old 11-06-2011, 03:26 PM   #8
An old Tradesmen
Rewards Points: 7,762
MOC should be an oil fired furnace.
The Following User Says Thank You to beenthere For This Useful Post:
ranbb (11-06-2011)
Old 11-06-2011, 03:55 PM   #9
Its an old fuel oil furnace. You have to clean the gun/nozzle assembly every year. Its a nasty mess. Best to find someone experienced in these units.
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
ranbb (11-06-2011)
Old 11-06-2011, 03:58 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 92
Yep. If not done properly it can drip oil in the combustion chamber, overload it, catch fire and trailers burn to the ground very easily. Don't reset it more than once or it may be coating the chamber with unburnt oil. Once that lights up the chamber turns red hot and you have an uncontrolled runaway wildfire.
The Following User Says Thank You to yuri For This Useful Post:
ranbb (11-06-2011)
Old 11-06-2011, 06:39 PM   #11
to doc
i took pics, can't get them to attach
Old 11-06-2011, 06:49 PM   #12
Hvac Pro
yuri's Avatar
Rewards Points: 92
It should also be setup properly by a Pro with a combustion analyzer so it burns cleanly and safely and efficiently. Otherwise the oil barons will be sending you Thank You notes and Xmas cards.
Lennox Furnace burner won't stay on stevea7777 HVAC 64 03-09-2017 05:39 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
RUUD gas furnace - flame will not stay on frostyfreeze HVAC 1 11-07-2008 11:25 PM
miller furnace booms when ignites Bigbang HVAC 1 03-10-2008 12:16 PM
Miller Mobile Home Oil Furnace jjalba9 HVAC 1 01-22-2007 10:57 AM
