Old 01-10-2009, 06:21 PM   #1
Miller Furnace Question
I have a 1994 mobile home with a miller furnace. The first problem we had was the blower was not kicking on long enough to cool off you had to run it manually. We tightened all wire connections to the blower and put on a new blower controller. Now we have another concern. The burner heats up to temp then the blower kicks on and runs. When the burner kicks off the blower cools it down and shuts off but does not come back on to recirculate the air. When it shuts off the first time the air is cool. Is this a problem. We have waited 3-4 minutes and turned fan on manually and the air comes out cold. We have been told that it probably runs longer the first time and cools it off enough that the blower doesn't need to come on again.
tink9497 is offline   Reply With Quote
Old 01-10-2009, 07:28 PM   #2
Hvac Pro
Most newer furnaces use a timer to control the length of time it runs B4 and after the burner is on. Miller determines what is safe for their unit so I would not worry about it. The OLD units had manual fan controls but I doubt if your does. Get a tuneup done yearly and ask the tech for more info. Running it cold is not a good idea as you could get condensation in the unit/chimney and that is bad for it.
Old 01-10-2009, 07:34 PM   #3
My furnace has a three way switch. On turns on whole system, off turns everything off and fan just turns on fan. If we want it to run through the second cool down we have to flip it to fan which becomes a pain. If it won't hurt the furnace to not run the second cool down I won't worry about. Thanks.
Old 01-10-2009, 09:31 PM   #4
The way it should work- Thermostat calls for heat. Burner fires and heats the heat exchanger. At a temperature, determined by the mfg., the blower comes on and runs. Once the thermostat is satisfied the burner shuts off. The blower continues to run until the heat exchanger cools down, then it will shut down and stay off until the burner fires for another cycle.
SKIP4661 is offline   Reply With Quote
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Miller Furnace Question feil08 HVAC 2 01-19-2008 06:58 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 03:04 PM
