Miller Furnace Oil Pump Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2011, 11:23 PM   #1
miller furnace oil pump problem
I have a verry old mobile home miller furnace no matter how long I leave the bleader valve open I keep getting air
brad j is offline   Reply With Quote
Old 01-25-2011, 02:31 AM   #2
An old Tradesmen
Rewards Points: 8,142
Then you have a air leak in your oil line somewhere. Or, your out of oil.
Old 01-25-2011, 06:42 AM   #3
thanks for the info I also noticed that i can get fuel to come out of the bleeder valve but no fuel to come out of the out line to the nozzle not a drip is the pump no good? I also have plenty of fuel thanks
Old 01-25-2011, 07:57 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,706
Ayuh,... How full of Crud is the oil Filter,..??
Old 01-25-2011, 10:26 AM   #5
It had a lot of crud but I cleaned it and took the pump apart and cleaned it also
Old 01-25-2011, 10:30 AM   #6
even Though i cleaned it thoroughly, it almost seems to act like a clogged carburator.
Old 01-25-2011, 10:36 AM   #7
Bondo's Avatar
Ayuh,... Then I'd Replace the pump, 'n the fuel Filter element...
The Following User Says Thank You to Bondo For This Useful Post:
brad j (01-25-2011)
Old 01-25-2011, 10:38 AM   #8
Thanks for the advice. I appreciate it!
Old 11-28-2012, 03:39 PM   #9
How to get air out of the system
hey BradJ did you ever figure out your problem will your Miller Furnace? MagicPatrick1 on youtube has the Anatomy of Oil Burner Service. If you have a filter it could be the oil filter you need to remove the nut at the top of it to drop it down and get the air out of there but according to the video do NOT touch the bleader on that if there is sludge in that unit clean it out and replace oil filter then close back up and then try to blead through blead tube. I'm telling you what the video states I am not a expert but alot of information he has given has been right on. If you own a beckette burner AF I can give you more inform if needed Let me know. I wish you the best.
overcomer888 is offline   Reply With Quote
Perplexing problem, Ruud furnace jbarker HVAC 43 01-20-2010 12:03 PM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 06:14 PM
Furnace problem...solution per contractor...please take a look gone_fishing HVAC 5 12-01-2008 05:40 PM
Miller Mobile Home Oil Furnace jjalba9 HVAC 1 01-22-2007 10:57 AM
